I too was getting notifications when I didnât used to. Try using the code below as a replacement to the SmartApp code. Once installed and activated, goto the smart app settings and select the correct options for notifications. Let me know if this corrects your issue. I need to get with Toby about rolling this into the GitHub page.
* SimpliSafe Monitor
* Author: toby@cth3.com
* Date: 2/7/2018
* Monitors and controls the state of a SimpliSafe alarm system, syncs with Smart Home Monitor and can turn on/off switches based on SimpliSafe state.
* Works in conjunction with SimpliSafe Alarm Integration device type.
// Automatically generated. Make future change here.
definition(
name: "SimpliSafe Monitor",
namespace: "tobycth3",
author: "Toby Harris",
description: "Monitors and controlls the state of a SimpliSafe alarm system, syncs with Smart Home Monitor and can turn on/off switchs based on SimpliSafe state. Works in conjunction with SimpliSafe Alarm Integration device type.",
category: "Safety & Security",
iconUrl: "https://pbs.twimg.com/profile_images/594250179215241217/LOjVA4Yf.jpg",
iconX2Url: "https://pbs.twimg.com/profile_images/594250179215241217/LOjVA4Yf.jpg")
preferences {
section("Monitor and control this SimpliSafe alarm system") {
input "alarmsystem", "capability.alarm", title: "Select alarm system"
section("Control these switchs") {
input "alarmtile", "capability.switch", title: "Select switches", multiple: true, required: false
section("Turn on switchs when SimpliSafe state matches") {
input "alarmon", "enum", title: "Select on state", multiple: true, required: false, metadata:[values:["off", "home", "away"]]
section("Turn off switchs when SimpliSafe state matches") {
input "alarmoff", "enum", title: "Select off state", multiple: true, required: false, metadata:[values:["off", "home", "away"]]
section("Notifications"){
input("recipients", "contact", title: "Send notifications to", required: false) {
input "sendPushMessage", "enum", title: "Send a push notification?", options: ["Yes", "No"], required: false
input "phone", "phone", title: "Phone Number (for SMS, optional)", required: false
paragraph "If outside the US please make sure to enter the proper country code"
def installed() {
init()
def updated() {
unsubscribe()
unschedule()
init()
def init() {
subscribe(alarmsystem, "alarm", alarmstate)
subscribe(location, "alarmSystemStatus", shmaction)
def updatestate() {
log.info("Checking SimpliSafe and Smart Home Monitor state")
state.alarmstate = alarmsystem.currentState("alarm").value.toLowerCase()
state.shmstate = location.currentState("alarmSystemStatus").value.toLowerCase()
log.debug("SimpliSafe: '$state.alarmstate', Smart Home Monitor: '$state.shmstate'")
def shmaction(evt) {
log.info "Smart Home Monitor: $evt.displayName - $evt.value"
state.shmstate_raw = evt.value
state.shmstate = state.shmstate_raw.toLowerCase()
if(shmOff && !alarmOff) {
log.debug("Smart Home Monitor: '$state.shmstate', SimpliSafe: '$state.alarmstate'")
setalarmoff()
else {
if(shmAway && !alarmAway) {
setalarmaway()
else {
if(shmStay && !alarmHome) {
setalarmhome()
else {
log.debug("No condition match Smart Home Monitor: '$state.shmstate', SimpliSafe: '$state.alarmstate'")
def alarmstate(evt) {
log.info "SimpliSafe Alarm: $evt.displayName - $evt.value"
state.alarmstate_raw = evt.value
state.alarmstate = state.alarmstate_raw.toLowerCase()
if (alarmOff && !shmOff) {
setshmoff()
else {
if (alarmAway && !shmAway) {
setshmaway()
else {
if (alarmHome && !shmStay) {
setshmstay()
else {
log.debug("No condition match SimpliSafe: '$state.alarmstate', Smart Home Monitor: '$state.shmstate'")
if (state.alarmstate in alarmon) {
log.debug("SimpliSafe state: $state.alarmstate")
alarmstateon()
else {
if (state.alarmstate in alarmoff) {
alarmstateoff()
else {
log.debug("No switch actions set for SimpliSafe state '${state.alarmstate}'")
def setalarmoff() {
updatestate()
log.debug("SimpliSafe: '$state.alarmstate'")
if (!alarmOff) {
def message = "Setting SimpliSafe to Off"
log.info(message)
sendMessage(message)
alarmsystem.off()
else {
if (alarmOff) {
log.debug("SimpliSafe already set to '$state.alarmstate'")
def setalarmaway() {
updatestate()
if (!alarmAway) {
def message = "Setting SimpliSafe to Away"
log.info(message)
alarmsystem.away()
else {
if (alarmAway) {
def setalarmhome() {
updatestate()
if (!alarmHome) {
def message = "Setting SimpliSafe to Home"
log.info(message)
alarmsystem.home()
else {
if (alarmHome) {
def setshmoff() {
updatestate()
log.debug("Smart Home Monitor: '$state.shmstate'")
if (!shmOff) {
def message = "Setting Smart Home Monitor to Off"
log.info(message)
sendLocationEvent(name: "alarmSystemStatus", value: "off")
else {
if (shmOff) {
log.debug("Smart Home Monitor already set to '$state.shmstate'")
def setshmaway() {
updatestate()
if (!shmAway) {
def message = "Setting Smart Home Monitor to Away"
log.info(message)
sendLocationEvent(name: "alarmSystemStatus", value: "away")
else {
if (shmAway) {
def setshmstay() {
updatestate()
if (!shmStay) {
def message = "Setting Smart Home Monitor to Stay"
log.info(message)
sendLocationEvent(name: "alarmSystemStatus", value: "stay")
else {
if (shmStay) {
def alarmstateon() {
log.debug ("Setting switches to on")
alarmtile?.on()
def alarmstateoff() {
log.debug ("Setting switches to off")
alarmtile?.off()
// TODO - centralize somehow
private getalarmOff() {
def result = false
if (state.alarmstate == "off") {
result = true }
log.trace "alarmOff = $result"
result
private getalarmAway() {
def result = false
if (state.alarmstate == "away") {
result = true }
log.trace "alarmAway = $result"
result
private getalarmHome() {
def result = false
if (state.alarmstate == "home") {
result = true }
log.trace "alarmHome = $result"
result
private getshmOff() {
def result = false
if (state.shmstate == "off") {
result = true }
log.trace "shmOff = $result"
result
private getshmAway() {
def result = false
if (state.shmstate == "away") {
result = true }
log.trace "shmAway = $result"
result
private getshmStay() {
def result = false
if (state.shmstate == "stay") {
result = true }
log.trace "shmStay = $result"
result
private sendMessage(msg) {
Map options = [:]
if (location.contactBookEnabled && recipients) {
sendNotificationToContacts(msg, recipients, options)
} else {
if (phone) {
options.phone = phone
if (sendPushMessage && sendPushMessage != 'No') {
log.debug 'Sending push and SMS'
options.method = 'both'
} else {
log.debug 'Sending SMS'
options.method = 'phone'
} else if (sendPushMessage && sendPushMessage != 'No') {
log.debug 'Sending push'
options.method = 'push'
} else {
log.debug 'Sending nothing'
options.method = 'none'
sendNotification(msg, options)
