Simple routine
Hello,
Newbie here.
Will this routine work?
When the light switch is turned on or the humidity hits 65%
The fan will turn on
There will be a delay of 30 minutes
Then the fan will shut off?
Does it need Fan is on in the If section? It will still run since you used any conditions.
Is that the Aqara H2 Wall Switch you were talking about?
Connect it directly to SmartThings (Matter/Thread or Zigbee) and you will get multiple devices (one for the buttons, and one for each channel). That way you won’t get confused.
Edit: context:
Edit2: I also have an H2 2CH in my bathroom to control a light and a fan. Since you won’t need the decoupled mode, just connect it via Matter/Thread to SmartThings.
And here’s my routine for the fan:
I could add the light as a precondition, but I don’t care if the light is on or not. It would look like this:
Yes, I want the fan to run only for 30 .
So, in the
IF section
The fan is turned on manually
Or
The humidity is above or equal to 65%
Then
The fan turned on for 30 minutes.
I hope that makes sense
