I have a Trane 950 thermostat and the only way to talk to it is via Nexia which supports IFTT. I’m trying to fully automate my HVAC set points via occupancy so I need to link conditionals like “if 6:30am and the virtual switch OCCUPIED is on, turn on the virtual switch MORNING-HOME”. I’ll then link that switch to Nexia via IFTT.
Is this a job for CoRE or have I missed some native capability for doing this in ST?
While I’m unfamiliar with Nexia, it does seem like something Core would handle. And no, I don’t believe you are missing any native app that would meet all your needs.
You should be able to find some good info on Core for what you need. If you are having any trouble getting started, you are welcome to PM me as well. I had to do some workarounds myself for HVAC needs.
You could do this natively with modes, but it would be a pain in the neck to do so. You basically have to create duplicates of every Mode you have now, one for when The presence indicator on and one for when the presence indicator is off. Then have a Smart lighting automation that turns the switch on at 6:30 AM but only if the correct Mode is set. It would work, but it would be annoying to set up. This is what people used to do before the rules engine alternatives existed. Some people had as many as 60 different modes to cover all the combinations they were trying to track.
A much easier way if you have an iOS phone is to use the third-party app, SmartRules, which has a “do while” option. It costs about $10 and is quite popular. Very easy to use. But it is limited in depth to the single “do while” condition. And there’s no android version.
