Show datetime for receiving last event on a tile?
Hi all, I have slightly modified the Smartsense Temperature + Humidity Sensor device handler so it displays celcius temperature with a decimal. (Thanks to another thread in here).
I would also like to display when the temperature was last reported/changed from the device in a tile.
How can I accomplish that?
Best regards
First create an attribute
attribute "lastActivity", "string"
then a tileAttribute
tileAttribute ("device.lastActivity", key: "SECONDARY_CONTROL") {
				attributeState "default", label:'Last activity: ${currentValue}', action: "refresh.refresh"
when you get a temperature update also do this…
def finalString = lastActivity?.format('MM/d/yyyy hh:mm a',location.timeZone)
	sendEvent(name: "lastActivity", value: finalString, display: false , displayed: false)
See my leakSmart sensor code for example.
