I’ve set up a door/window sensor in SHM with a notification if the sensor opens (Custom setup). Problem is, the time units are in whole minutes. The gives someone plenty of time to open and then close the door within 1 minute and no notification being sent. Ideally I need it to notify when the switch is opened. Is this possible in SHM.
Note, I’m using v2 and lastest android app. Thanks
