SHM is not working. when i arm it won’t arm and when i disarm it won’t disarm. it wont work with routines, rules or anything.
When ever i need to arm the system first i try to arm it. it keeps on rotate and says issue with network and won’t arm. then i have to delete configuration and re create it. once i setup SHM then i can arm. to disarm when press disarm it keeps on rotates again and never disarms.and says network error. if i walk in it blow my alarm. i have to delete configuration and setup again to disarm.
You’ve been complaining since January, if wink truely worked better… Why haven’t you switched back and saved yourself all the frustration. Seriously dude it’s time to or get off the pot.
