SHM auto changing to armed, setting off alarm (Jan 2021)
Known issue and there are two different things that can cause it: preconditions having been deleted from your automations, which happened to some people, or changes to the “virtual switch“ DTH, so that you should use the “simulated switch“ DTH instead.
Both of these changes were undocumented and happened at about the same time, which is really annoying. :rage:
See the following thread:
Outage Affecting STHM and some automations (19 Jan 2021)
