Is there a ST Arduino Shield equivalent for the Raspberry Pi?
if not, fas anyone connected the ST Shield to a Pi?
The approach I have seen and will probably also use at some point is just using LAN interaction with the pi from the hub.
Something like this:
Right, you shouldn’t need the shield for the pi because the pi has its own connectivity.
You can look at some of the existing raspberry pi projects and see what people have done.
If you check the quick browse lists in the community – created wiki, look under DTH (device type handlers) and look near the end for “miscellaneous,” you should find several there.
