So, 4th time in two months, Shelly integration is broken. And Scandinavian Tibber have removed information about Smartthings integration. Is it just me? Really thrilled about Smartthings when I started but this is just too much hassle. Is it all Shellys fault or what’s happening. At least I’ve learned not to remove and connect again to Shelly, which created duplicates of devices.
If you haven’t tried already… the easiest way to reconnect is to go to menu > settings > linked services and open the Shelly integration and click through the screens.
I do not have Shelly devices so I can’t answer the other questions.
Yeah I know, but it’s starting to get tiresome and feeling unreliable. And not sure where Smartthings is going
For the fifth time, come on…
I’ve been facing the exact same problems. I would say that is an issue of credentials expiration… I rose an issue in Shelly support and they are in the process of analyzing it. Till now they have told me that the problem doesn’t seem to be on their side and they have also ask me not to reconnect the next time it happens, cause it may eventually get back to work on it’s own.
Same issue here… loosing connection every couple of days…
Did you lost the connection today? Because so did I. I thought it was something related with credentials expiration or similar (a token they are keeping behind the scene), but if connection is lost at the same time for all the users, then it should be other thing…
Yes i did. and also yesterday
Just got a message from shelly from their support. They know about the issue and say it is on smartthings side. They are already in contact with smartthings regarding that issue and ask for patience…
So Shelly integration has been better. But after adding more devices in Shelly and removing one Smarthings don’t update. Previously I could reconnect with wizard but now I can only remove??
2 new devices finally appeared. But one device removed from Shelly is still in Smartthings. …and can’t be added again in Shelly…but that’s a case for Shelly support… that’s been going on for some weeks now…the not so funny part of home automation.
