Setting value of Virtual Temp Sensor
So have done a little homework for you… :slight_smile:
setTemperature(value) is supported in the DTH, but doesn’t exist in CoRE probably for the same reason as detailed in my previous post… you could add the command yourself, but updating CoRE will remove this. I think your best option is just to use setLevel, which I assume isn’t an issue?
DTH below:
also on my hunt… you may want to look at the below as there are a couple of smartApps doing exactly what you want to do:
