I am at the point in setup where I am setting up my profile and also adding the slot types and all that. I am kinda lost. It seems something is missing from the walkthrough. I am not exactly sure what a profile is and how it is used. Due to that confusion, I am not sure how to get all the values for all the slot types. I know the walkthrough shows about 8 different slot types but I am not sure where all the values for each slot type are coming from.
For the custom slot types go to https://raw.githubusercontent.com/BamaRayne/Echosistant/master/smartapps/echo/AWS_Files/MainCustomSlots
You will get the values for the profile slot types here http://thingsthataresmart.wiki/index.php?title=EchoSistant
For the LIST OF DEVICES you will get that from your live logging mentioned on step 5.
Scroll down to:
Select the link for profile, then select RAW. Then on that page ctrl +A, then ctrl +C. That will then be pasted ctrl +V on the interaction model BETA page.
Ok, I got past that part I think. I went to the next step where I am on the CONFIGURATION part under the main intent set up. I set it up to use AWS Lambda ARN (Amazon Resource Name) and set the location to North America with my ARN number. I get this at the bottom now though
Error: Please make sure that “Alexa Skills Kit” is selected for the event source type of arn:aws:lambda:us-east-X:XXXXXXXXXXXXX:function:EchoSistant
I’ll look at the page on my home computer once I get home from work. I started the setup today also; however, the work computers firewall aren’t playing nice with the developer site. I’m at about the same step you are.
Yup Ohio doesn’t have that skill. I ran into the same thing.
The documentation states that N. Virginia definitely works, while the others may or may not have that functionality.
PS I tried Ohio as it was the closest server to me.
