Hi SmartThings Support Team,
I am having an issue with the zigbee.command().
zigbee.command(0x0006,0x00, [destEndpoint:0x08]);
If I execute this command I am getting an error
groovy.lang.MissingMethodException: No signature of method: physicalgraph.zigbee.Zigbee.command()
What seems to be the problem?
That’s very hard to diagnose without being able to see all the rest of your code, or a good portion of it at least.
Are you getting any errors when doing any of these?:
zigbee.parseDescriptionAsMap()
zigbee.configureReporting()
zigbee.on()
zigbee.off()
Hi John,
Thank you for the response. But I have figured out where the problem is and it is because I am missing a parameter.
from
zigbee.command(0x0006,0x00, [destEndpoint: 0x09]);
to
zigbee.command(0x0006,0x00, “”, [destEndpoint: 0x09]);
The quatation mark was for payload. And in this case for 0x0006 cluster it doesn’t necessarily need it but when I need to add more parameters, I have to fill this in even I have to put it blank.
