Kristopher
(Kristopher Kubicki)
October 27, 2015, 5:35pm
#1
I’ve seen this behavior for a while, but I always just figured I’d code around it. But then I realized it’s probably a more serious issue.
What I’ve seen happen is if a slider has a range set into the negative values like this:
controlTile("level", "device.level", "slider", height: 1, width: 2, inactiveLabel: false, range: "(-800..100)") {
The slider will update fine if the user changes the slider – at least for Android. However, if ST updates via sendEvent(), the slider will not update if the value is negative. Usually this wouldn’t matter, but for things like my Yamaha network receiver, the volume is on a scale of -800cdB to +100cdB
* Yamaha Network Receiver
* Works on RX-V*
* SmartThings driver to connect your Yamaha Network Receiver to SmartThings
* Loosely based on: https://github.com/BirdAPI/yamaha-network-receivers
* and: http://openremote.org/display/forums/Controlling++RX+2065+Yamaha+Amp
preferences {
input("destIp", "text", title: "IP", description: "The device IP")
input("destPort", "number", title: "Port", description: "The port you wish to connect")
input("inputChan","enum", title: "Input Control", description: "Select the inputs you want to use", options: ["TUNER","HDMI1","HDMI2","HDMI3","HDMI4","HDMI5","AV1","AV2","AV3","AV4","AV5","V-AUX","AUDIO1","AUIDO2","SERVER","NET RADIO","USB"],multiple: true,required: true)
metadata {
definition (name: "Yamaha Network Receiver", namespace: "KristopherKubicki",
author: "kristopher@acm.org") {
capability "Actuator"
This file has been truncated. show original
Let me know if this helps at all
Kristopher
