Right now I have a virtual button that use to tell webcore to slowly turn on some lights at 7:30 am. Is there some app that I could use to pass more information than on/off to webcore? For example, I would like to be able to set the time at which webcore should start turning the lights instead of just having it hardcoded.
Why do you need a virtual button for time? You can just setup a Piston with the time at 7:30. Only time you need a virtual button to set is random time.
Ok, Do you have Alexa or Google home? You can have a virtual switch and tell Alexa or Google to turn off if you didn’t want to wake up.
A button such as Minimote or Xiaomi button or a wireless switch. Switch the button will pause the Piston or ignore the timer for that morning. There are quite a few ways to go about this.
I would like to change the happens daily at 7:30 am to a variable that I can configure using the smartthings app
tgauchat
8
This is a great question and the concept is useful for many scenarios.
There are several ways it could be done and I don’t know the best way, but here’s one idea:
Create a Device Type of any numeric value (eg, Power). Add up/down sub-tiles to the Device Type Handler and/or a companion SmartApp input field where you can input the desired Time. Use this Device’s current Attribute value in your Piston rather than a hard-coded number (time).
Thanks @tgauchat ! This is exactly what I had in mind? Do you know how hard it would be to implement? Is there a tutorial that I could follow to do this? I have no experience creating Device Handlers nor SmartApps
tgauchat
11
Harder than it ought to be !
The code would be pretty easy and not big, but the smallest mistake or quirk would be frustrating and just as likely with a template starting point.
But it is worth the effort if you want to learn.
Start with the Developer Docs and experiment by modifying some sort of Virtual Sensor code…?
