Recently connected motion sensor to new app and it won’t show up on the main screen. You can only accessible it from inside a room. It does show up in IDE as well. Any thoughts?
How many devices do you have on your account?
15-20 devices
so to sum up…
menu > rooms > the device appears in its correct room?
does it show in menu > devices?
on dashboard, have you clicked on 3 dots in the upper right of the screen, select Edit, click on the room and looked to see if that the device is check marked so it shows on dashboard?
The sensor wasn’t checked marked, thanks for the tip.
