rednose66
(Jon)
September 13, 2017, 12:51pm
1
Hi all
I have just installed a sensibo sky which is not responding to the ST smartapp. It doesn’t respond to Alexa either. The odd thing is that I am getting temp and humidity alerts from ST. I’ve added the API key to ST and linked my Alexa account. Any ideas?
Assuming you’re using this integration by a community developer, try asking for help in the thread he created.
NOTE : This project is no longer maintained by the author. This integration required the classic SmartThing app, this is not supported under the new app.
The new Smartthing app support Sensibo but this not related to this projet. Please contact Sensibo for any issue with the new app.
The code source of my Device Handler and SmartApp are available on GitHub and it is free to use and modify if you want.
I created a Sensibo integration, this is including a Service Manager to communicate with Sensibo servers and a SmartApp to manage your Sensibo Pod at home using SmartThings.
[Screenshot_20190604-080644_SmartThings]
My projects can be found here:
SmartApp:
https://github.com/EricG66/SmartThingsPublic/tree/MSA-635-1/smartapps/ericg66/sensibo-connect.src
Device Handler (Should be …
Good point Mark! I’ll do that thanks.
