@Brutalboy I’m having a strange issue when I try to control my pods through SmartThings.
If the temperature on my a/c is already set to an odd number, tapping the up or down button once causes my a/c to change by two degrees Fahrenheit. If the temperature is an even number, then I am able to change temp by one degree Fahrenheit.
This is occurring with two a/c’s from different brands. And everything works normally when I use the sensibo app. I have the first generation pods, and the most recent version of your device handler and smartapp.
Both a/c’s are Fahrenheit, I’m in the US. I can use each a/c’s native remote, and the sensibo app, to increase/decrease by 1 degree Fahrenheit without any problems. Sensibo app is set to Fahrenheit.
I just recently installed the Sensibo Sky and got it configured with SmartThings. I’m running into an issue with the Auto thermostat mode.
Sensibo allows the auto mode to substitute for “energy saver”/“econ” with Frigidaire window ACs. I saw in the DTH code that you had commented out the auto setting. I tried reenabling it and making the necessary tweaks to NextState values and updating the commands to reflect this change, however although the device correctly reads “auto” when the Sensibo is set to that setting externally, I’m not able to actually set the auto mode through SmartThings. I don’t use “heat” or “dry” and I even tried commenting out those values.
The device is throwing an error message: “FAILED to set or get the AC State” when I attempt to set the mode to “auto.” Then the mode button then gets stuck at “fan only” and I can’t set it back to “cool” or anything else within SmartThings. I’m certainly not a Groovy expert so it’s likely I’m missing a setting (or a few) somewhere. Can you please offer some guidance? Thank you.
Auto mode is a work-in-progress. This is why it is commented. I have some issue with auto mode at this moment and did not have any time to to debug it.
My A/C is also supporting auto mode but I’m missing time to test and do it.
@Brutalboy any other thought as to why I’m seeing that strange behavior with temp changes going up/down by 2 degrees Fahrenheit, but only from the ST app, and only when the a/c setpoint is currently an odd number? Thanks.
I really appreciate your hard work man. But I uninstalled the device, updated the DTH and reinstalled it. I’m still having the same issue where it just gets stuck on fan only mode.
The button’s icon/bkgrd continue to update correctly but after fan only, the rest of the interface seems to freeze and no commands work from any of the controls except powering off, with the inability to power back on. It’s also still throwing the “Failed to set or get the Ac State” error.
Thanks Eric, I sent you a private message with the requested info.
Mark -
The 2nd URL to get the capabilities also requires the PodID you got from the 1st. i.e., https://home.sensibo.com/api/v2/pods/[PodID]/?[apiKey]=&fields=remoteCapabilities,productModel
Also the community board limits message attachments to image files I just learned. I just pasted the results into the PM.
I purchased a Sensibo Sky, and have it all set up. I published the app and the device handler, but after I enter my api key, it doesn’t find any pods. I have double-checked the key and entered it multiple times… even tried recreating the key a few times. Anything I am doing wrong? I don’t have to setup the device in smartthings first, right?
