SmartThings Community
Sensibo integration
smartapp_hvac
#589
Logs sent to you
#590
Hey @Brutalboy - did more testing, only the Living Room Thermostat changes when I change SHM. Bedroom and Milan’s room don’t change.
#591
Please try them one by one. I m suspecting the way you are calling them in webcore.
Eric
-------- Message d’origine --------
#592
Ok, I’ll update. Makes sense.
#593
Hi Eric
Did you get a chance to look at my logs I sent?
(Michael Orbon) #594
Eric,
It almost works. Screenshot shows that with the correct vid in the metadata, the display is this…(only Temp unit is incorrect)
#596
@Iresler13
I would recommend using setAll to avoid multiple call to the AC
example in webCoRe setAll(mode as string ,temp as integer ,fanlevel as string)
setAll( ‘cool’,22,‘auto’)
NOTE: The capabilities list depend on your AC as they may be limited
The fan level values are:
low,medium,high,auto,quiet,medium_high,medium_low,strong
The swing values are:
stopped,fixedTop,fixedMiddleTop,fixedMiddle,fixedMiddleBottom,fixedBottom,rangeTop,rangeMiddle,rangeBottom,rangeFull,horizontal,both
#597
On my Android Galaxy S9, I cannot set the thermostat mode or other, I can only turn on/off for the moment.
Which platform are you on?
#598
Hey @Brutalboy , still doing some testing and getting overall great results. What is this error in Webcore?
WARNING: Results may be unreliable because the parent app’s version (v0.3.109.20181207) is newer than the child app’s version (v0.3.108.20180906). Please consider updating both apps to the same version.
#599
This error seem to come from webCoRE and not my stuffs. Please update webCoRE to latest version from smartthing web site.
#600
(Michael Orbon) #601
Eric,
Sorry for the wait for my reply! I am on iOS. That is an iPad. Hope this helps.
(Chris) #602
I purchased 2 Sensibo Sky units for both my Fujitsu Heat Pumps and they work perfectly. I am using your SmartApp with ST and Webcore and it works perfectly to control the temperature.
Thank you!
(Stian Ranvik) #603
I’m using the latest EricG66 app/dh.
In auto mode, when i change temperature: one of my heat pump always change mode, first heating then stays in cooling. The other heatpump works.
  • Have tried added it again. It works as it should in sensibo app.
  • Also have tried disabling the webcore controll.
  • The “Auto-mode” button doesnt work, but changing with the heat-cool-fan-auto button work.
Last log when changing temp in auto:
ad744447-2acc-4936-9a58-5025f7b7a1b5
14:21:51: trace refresh() ended
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:51: debug name :targetTemperature value :29
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:51: debug name :switch value :on
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:48: trace temperatureDown() called with 30
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:48: trace lowerTemperature() called
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:51: debug name :thermostatMode value :cool
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:51: debug name :voltage value :3000
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:51: debug name :coolingSetpoint value :29
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:50: trace setCoolingSetpoint() called
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:50: debug name :productModel value :skyv2
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:49: info Heating temperature changed to 29 for 98arunzT
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:49: trace Executing ‘poll’ using parent SmartApp
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:49: trace refresh() called
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:48: debug setTemperature : 29
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:48: debug Temp after : 29
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:48: debug Temp before : 30
ad744447-2acc-4936-9a58-5025f7b7a1b5 14:21:48: debug Current target temperature = 30
(Stevenk22) #604
Hey there all, I had a friend ask me yesterday to help him find a way to allow AirBNB customers control several Sensibo controllers at one time with some sort of tablet. Has anyone tried to put this up on ActionTiles to control their Sensibo from a Tablet?
#605
yup. create a virtual switch and the have it trigger a webcore piston with the desired temp/rooms.
(Jeremy Lechterman) #606
Hey Brutalboy. I’ve installed the smartapp and device handler as your instructions, but when I go to the marketplace to find the app, its not there. Thoughts?
#607
You have installed and published them?
You are looking in My Apps section?
Eric
(Jeremy Lechterman) #608
It was a failure in the IDE. I got it working. Sorry to bother.
