I tried to apply your change and i reached another error in the device handler e93f864d-6d4a-4fa4-bddd-38798e752c6c 14:59:43: error groovy.lang.MissingPropertyException: No such property: fanLevels for class: java.lang.String @line 245 (setAll) e93f864d-6d4a-4fa4-bddd-38798e752c6c 14:59:42: trace setAll() called with cool,20,auto
What do you mean to test only inside smart things? The problem seems to be related to setAll method which it’s not exposed as an action in the DTH. I can only call it from webcore which is what I was doing until reaching the errors described
@Brutalboy is it possible to clean up the recently feed to only display when there is an actual change? I dont need to see it flooded with things like power source, temp unit etc
Hi, iwas wondering what i am doing wrong. Installed the smartappa dn device handler and was able to pull up my sensibo sky 2 but couldnt controle anythig except truning my heatpump on and off. Not sure what to do. Thanks
I have the same problem. I dont know when it started. But I’m only able to turn it on/off. It was working fine before.
Here are some logs:
Smartapp:
[add63d81-9a35-45b3-8674-46a67ec4dbb1](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#add63d81-9a35-45b3-8674-46a67ec4dbb1) 10:20:25: debug get remoteCapabilities Failed
[add63d81-9a35-45b3-8674-46a67ec4dbb1](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#add63d81-9a35-45b3-8674-46a67ec4dbb1) 10:20:25: debug Status : 200
[add63d81-9a35-45b3-8674-46a67ec4dbb1](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#add63d81-9a35-45b3-8674-46a67ec4dbb1) 10:20:25: trace getCapabilities() called - Request sent to Sensibo API(remoteCapabilities) for PODUid : abL73RoM - SmartThingsv1.5
[add63d81-9a35-45b3-8674-46a67ec4dbb1](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#add63d81-9a35-45b3-8674-46a67ec4dbb1) 10:20:25: debug Now : 1537086025218 Next : 60000
Device:
[8326ac4e-39f4-4ab8-87b3-5adbe3dc57d7](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#8326ac4e-39f4-4ab8-87b3-5adbe3dc57d7) 10:20:25: error groovy.lang.MissingPropertyException: No such property: temperatures for class: java.lang.String @line 344 (temperatureUp)
[8326ac4e-39f4-4ab8-87b3-5adbe3dc57d7](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#8326ac4e-39f4-4ab8-87b3-5adbe3dc57d7) 10:20:25: trace temperatureUp() called with 21
[8326ac4e-39f4-4ab8-87b3-5adbe3dc57d7](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#8326ac4e-39f4-4ab8-87b3-5adbe3dc57d7) 10:20:25: debug Current target temperature = 21
[8326ac4e-39f4-4ab8-87b3-5adbe3dc57d7](https://graph-eu01-euwest1.api.smartthings.com/ide/logs#8326ac4e-39f4-4ab8-87b3-5adbe3dc57d7) 10:20:25: trace raiseTemperature() called
I’m interested in calling your switchFanLevel command within my zoned heating/cooling smartapps. Your current implementation doesn’t allow it as the command can only be used within your DTH.
Could you change your switchFanLevel to accept an optional parameter (i.e. high, medium, low) with a null default value or even better implement the following commands?
5d7b8911-78dd-4026-a8ef-e7d3a635c6d3 00:01:37: trace getCapabilities() called - Request sent to Sensibo API(remoteCapabilities) for PODUid : pAFpwVBz - SmartThingsv1.5
Eric, first I want to thank you for your work. If you have a Paypal account for donations, please PM me as I would like to contribute. I have installed your Sensibo integration but am having an issue.
I set the temp to 78 F. and it shows that the temp is set to 78 but it never shuts off and keeps dropping. I turned it off at 72.
Also, I am in the tropics and we don’t have heaters. Can the heat related buttons be removed?
Again, thanks for your work. It’s awesome of you to share!
