Select Multiple Switches, but only turn one off?
Hello,
I am trying to build a app that I can control from the API. What I want to do is select a number of switches and then selectively turn them off… Everything is working how I expected except I can not find a way to only turn off one switch… switches.off(); turns them all off, and I can’t figure/find a syntax for switches.“switchName”.off(); This must be possible?? right?
This is the idea, where “switchName” is a name passed to the SmartApp via HTTP.
preferences {
section (“Allow external service to control these things…”) {
input “switches”, “capability.switch”, multiple: true, required: true
You’ll probably want something like:
def theSwitch = switches.find { it.displayName == theName }
theSwitch.off()
I was sooo close…Thanks that worked great! I knew there must be a way to do it.
B
