I have the other side of the problem. My Good Morning routine is not disarming the SHM, so I’m getting al my lights turned on when there’s still people in bed and a siren making all that noise.
I am getting too many intrusions. I haven’t enabled the siren because of all the nonsense around routines, schedules, and presence not working properly. Ergo the integration with Scout monitoring is funny.
I’ve been getting tons of intrusions a day on the back door, so I took it out of the mix. At first I chalked it up to wind. But after weeks of this, I wasn’t convinced about that. I’m hesitant to install a siren because of it.
I did get an email from ST support after hitting them up again…
In the meantime, one thing we’ve found to get around this problem is during the Smart Home Monitor setup, selecting your siren under the “Alert with Lights” alert type (instead of “Alert with Sirens” appears to work. Please give this a shot, and I’ll let you know as soon as I have more information on this problem.
Very sorry for the inconvenience, and please let me know if you have any other questions!
I got an email back from support regarding a different issue. They said they made some enhancements after the DB and hub upgrade. It did bring stability. Although every so often I see in the logs that the backdoor was open, when in fact it wasn’t. I’ve since taken it out of the mix so I do not get false positives in the intrusion detection.
