Hi,
So I have the Securifi SZ-PIR02 motion sensor working with ST now. Will post a link to the code shortly.
metadata {
definition (name: "Securifi SZ-PIR02", namespace: "sozonoff", author: "Sozonoff") {
capability "Motion Sensor"
capability "Sensor"
capability "Configuration"
capability "Refresh"
command "enrollResponse"
fingerprint inClusters: "0000,0003,0500", outClusters: "0003"
// simulator metadata
simulator {
status "active": "zone report :: type: 19 value: 0031"
status "inactive": "zone report :: type: 19 value: 0030"
// UI tile definitions
tiles {
standardTile("motion", "device.motion", width: 2, height: 2) {
state("active", label:'motion', icon:"st.motion.motion.active", backgroundColor:"#53a7c0")
state("inactive", label:'no motion', icon:"st.motion.motion.inactive", backgroundColor:"#ffffff")
standardTile("refresh", "device.refresh", inactiveLabel: false, decoration: "flat") {
state ("default", action:"refresh.refresh", icon:"st.secondary.refresh")
main (["motion"])
details(["motion","refresh"])
def configure() {
log.debug("** PIR02 ** configure called for device with network ID ${device.deviceNetworkId}")
String zigbeeId = swapEndianHex(device.hub.zigbeeId)
log.debug "Configuring Reporting, IAS CIE, and Bindings."
def configCmds = [
"zcl global write 0x500 0x10 0xf0 {${zigbeeId}}", "delay 200",
"send 0x${device.deviceNetworkId} 1 1", "delay 1500",
"zcl global send-me-a-report 1 0x20 0x20 0x3600 0x3600 {01}", "delay 200",
"zdo bind 0x${device.deviceNetworkId} 1 1 0x001 {${device.zigbeeId}} {}", "delay 1500",
"raw 0x500 {01 23 00 00 00}", "delay 200",
return configCmds + refresh() // send refresh cmds as part of config
def refresh() {
log.debug("** PIR02 ** refresh called for PIR02")
"st rattr 0x${device.deviceNetworkId} 1 1 0x20"
def enrollResponse() {
log.debug "Sending enroll response"
// Parse incoming device messages to generate events
log.debug("** PIR02 parse received ** ${description}")
Map map = [:]
if (description?.startsWith('zone status')) {
map = parseIasMessage(description)
log.debug "Parse returned $map"
def result = map ? createEvent(map) : null
if (description?.startsWith('enroll request')) {
List cmds = enrollResponse()
log.debug "enroll response: ${cmds}"
result = cmds?.collect { new physicalgraph.device.HubAction(it) }
return result
private Map parseIasMessage(String description) {
List parsedMsg = description.split(' ')
String msgCode = parsedMsg[2]
Map resultMap = [:]
switch(msgCode) {
case '0x0030': // Closed/No Motion/Dry
log.debug 'no motion'
resultMap.name = 'motion'
resultMap.value = 'inactive'
break
case '0x0031': // Open/Motion/Wet
log.debug 'motion'
resultMap.value = 'active'
break
case '0x0032': // Tamper Alarm
log.debug 'motion with tamper alarm'
break
case '0x0033': // Battery Alarm
break
case '0x0034': // Supervision Report
log.debug 'no motion with tamper alarm'
break
case '0x0035': // Restore Report
break
case '0x0036': // Trouble/Failure
log.debug 'motion with failure alarm'
break
case '0x0038': // Test Mode
break
return resultMap
private hex(value) {
new BigInteger(Math.round(value).toString()).toString(16)
private String swapEndianHex(String hex) {
reverseArray(hex.decodeHex()).encodeHex()
private byte[] reverseArray(byte[] array) {
int i = 0;
int j = array.length - 1;
byte tmp;
while (j > i) {
tmp = array[j];
array[j] = array[i];
array[i] = tmp;
j--;
i++;
return array
Its not all done yet but the motion detection seems to work. Not sure at all why my Refresh Tile is not showing up in ST Appā¦ Consider this work in progress.
Serge
