OK I have got something working.
There is still some sort of problem after you do the âConfigure New Deviceâ, as it shows up as a Thing, so I had to change the device to SRT321 Thermostat in the IDE, but it seems to be mostly working.
I have added a helper app to select a switch to be controlled by the thermostat⊠sore point as I maintain that SmartThings are wrong in their design and devices should be able to control / select other devices in their preferencesâŠ
/* SRT321 Device Handler by MeavyDev */
metadata
definition (name: âSRT321 Thermostatâ, namespace: âmeavydevâ, author: âMeavyDevâ)
capability "Temperature Measurement"
capability "Thermostat"
capability "Configuration"
capability "Polling"
capability âSensorâ
command "switchMode"
command "quickSetHeat"
command "setTemperature"
command "setupDevice"
fingerprint deviceId: "0x0800"
fingerprint inClusters: "0x72, 0x86, 0x80, 0x84, 0x31, 0x43, 0x85, 0x70, 0xEF, 0x40, 0x25"
// simulator metadata
simulator
tiles (scale: 2)
multiAttributeTile(name:"heatingSetpoint", type: "thermostat", width: 6, height: 4, canChangeIcon: true)
tileAttribute ("device.heatingSetpoint", key: "PRIMARY_CONTROL")
attributeState("default", unit:"dC", label:'${currentValue}°')
tileAttribute("device.heatingSetpoint", key: "VALUE_CONTROL")
attributeState("default", action: "setTemperature")
tileAttribute("device.temperature", key: "SECONDARY_CONTROL")
attributeState("default", label:'${currentValue}', unit:"dC")
tileAttribute("device.thermostatMode", key: "THERMOSTAT_MODE")
attributeState("off", label:'${name}')
attributeState("heat", label:'${name}')
tileAttribute("device.heatingSetpoint", key: "HEATING_SETPOINT")
tileAttribute("device.thermostatMode", key: "OPERATING_STATE")
attributeState("off", backgroundColor:"#44b621")
attributeState("heat", backgroundColor:"#ffa81e")
valueTile("battery", "device.battery", inactiveLabel: false, decoration: "flat", width: 2, height: 2)
tileAttribute ("device.battery", key: "PRIMARY_CONTROL")
state "battery", label:'${currentValue}% battery', unit:""
standardTile("refresh", "device.thermostatMode", inactiveLabel: false, decoration: "flat", width: 2, height: 2)
state "default", action:"polling.poll", icon:"st.secondary.refresh"
standardTile("configure", "device.configure", inactiveLabel: false, decoration: "flat", width: 2, height: 2)
state "configure", label:'', action:"configuration.configure", icon:"st.secondary.configure"
main "heatingSetpoint"
details(["heatingSetpoint", "battery", "refresh", "configure", "temperature", "mode"])
preferences
section (âWakeup intervalâŠâ)
input âuserWakeUpIntervalâ, ânumberâ, title: âWake Up Interval (seconds)â, description: âDefault 3600 sec (10 minutes - 7 days)â, defaultValue: â3600â, required: false, displayDuringSetup: true
// This is the "Device Network Id" displayed in the IDE
section ("Associated z-wave switch network Id...")
input "userAssociatedDevice", "string", title: "Associated switch ZWave network Id (hex)", required: false, displayDuringSetup: true
def parse(String description)
// log.debug âParse $descriptionâ
def result = zwaveEvent(zwave.parse(description, [0x72:1, 0x86:1, 0x80:1, 0x84:2, 0x31:1, 0x43:1, 0x85:1, 0x70:1, 0xEF:1, 0x40:1, 0x25:1]))
if (!result)
log.warn "Parse returned null"
return null
// log.debug "Parse returned $result"
result
def configure()
state.configNeeded = true
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev1.ThermostatModeSet cmd)
def map = [:]
switch (cmd.mode) {
case physicalgraph.zwave.commands.thermostatmodev1.ThermostatModeSet.MODE_OFF:
map.value = "off"
break
case physicalgraph.zwave.commands.thermostatmodev1.ThermostatModeSet.MODE_HEAT:
map.value = âheatâ
map.name = "thermostatMode"
createEvent(map)
// Event Generation
def zwaveEvent(physicalgraph.zwave.commands.thermostatsetpointv1.ThermostatSetpointReport cmd)
def map = [:]
map.value = cmd.scaledValue.toString()
map.unit = cmd.scale == 1 ? âFâ : "C"
map.displayed = false
switch (cmd.setpointType) {
case 1:
map.name = "heatingSetpoint"
break;
default:
return [:]
// So we can respond with same format
state.size = cmd.size
state.scale = cmd.scale
state.precision = cmd.precision
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv1.SensorMultilevelReport cmd)
def map = [:]
map.value = cmd.scaledSensorValue.toString()
map.name = "temperature"
createEvent(map)
// Battery powered devices can be configured to periodically wake up and
// check in. They send this command and stay awake long enough to receive
// commands, or until they get a WakeUpNoMoreInformation command that
// instructs them that there are no more commands to receive and they can
// stop listening.
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpNotification cmd)
def map = [name:âthermostatWakeUpâ, value: â${device.displayName} woke upâ, isStateChange: true]
def event = createEvent(map)
def cmds = updateIfNeeded()
cmds << zwave.wakeUpV2.wakeUpNoMoreInformation().format()
log.debug "Wakeup $cmds"
[event, response(delayBetween(cmds, 1000))]
def zwaveEvent(physicalgraph.zwave.commands.batteryv1.BatteryReport cmd)
def map = [ name: âbatteryâ, unit: â%â ]
if (cmd.batteryLevel == 0xFF)
{ // Special value for low battery alert
map.value = 1
map.descriptionText = "${device.displayName} has a low battery"
map.isStateChange = true
else
map.value = cmd.batteryLevel
log.debug (âBattery: $cmd.batteryLevelâ)
// Store time of last battery update so we donât ask every wakeup, see WakeUpNotification handler
state.lastbatt = new Date().time
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.thermostatmodev1.ThermostatModeReport cmd)
def map = [:]
switch (cmd.mode) {
case physicalgraph.zwave.commands.thermostatmodev1.ThermostatModeReport.MODE_OFF:
map.value = "off"
break
case physicalgraph.zwave.commands.thermostatmodev1.ThermostatModeReport.MODE_HEAT:
map.value = "heat"
break
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpIntervalCapabilitiesReport cmd)
def map = [ name: âdefaultWakeUpIntervalâ, unit: âsecondsâ ]
map.value = cmd.defaultWakeUpIntervalSeconds
state.defaultWakeUpInterval = cmd.defaultWakeUpIntervalSeconds
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.wakeupv2.WakeUpIntervalReport cmd)
def map = [ name: âreportedWakeUpIntervalâ, unit: âsecondsâ ]
map.value = cmd.seconds
createEvent(map)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd)
log.debug âZwave event received: $cmdâ
def zwaveEvent(physicalgraph.zwave.Command cmd)
log.warn âUnexpected zwave command $cmdâ
// Command Implementations
def poll()
// state.refreshNeeded = true
def refresh()
def quickSetHeat(degrees)
setHeatingSetpoint(degrees, 1000)
log.debug(âDegrees at quicksetheat: $degreesâ)
def setTempUp()
def newtemp = device.currentValue(âheatingSetpointâ).toInteger() + 1
log.debug "Setting temp up: $newtemp"
sendEvent(name: âheatingSetpointâ, value: newtemp)
quickSetHeat(newtemp)
def setTempDown()
def newtemp = device.currentValue(âheatingSetpointâ).toInteger() - 1
log.debug "Setting temp down: $newtemp"
def setTemperature(temp)
log.debug "setTemperature $temp"
sendEvent(name: âheatingSetpointâ, value: temp)
quickSetHeat(temp)
def setHeatingSetpoint(degrees, delay = 30000)
setHeatingSetpoint(degrees.toDouble(), delay)
log.debug(âDegrees at setheatpoint: $degreesâ)
def setHeatingSetpoint(Double degrees, Integer delay = 30000)
log.trace "setHeatingSetpoint($degrees, $delay)"
def deviceScale = state.scale ?: 1
def deviceScaleString = deviceScale == 2 ? âCâ : "F"
def locationScale = getTemperatureScale()
def p = (state.precision == null) ? 1 : state.precision
def convertedDegrees
if (locationScale == "C" && deviceScaleString == "F")
convertedDegrees = celsiusToFahrenheit(degrees)
else if (locationScale == "F" && deviceScaleString == "C")
convertedDegrees = fahrenheitToCelsius(degrees)
else
convertedDegrees = degrees
log.trace "setHeatingSetpoint scale: $deviceScale precision: $p setpoint: $convertedDegrees"
state.deviceScale = deviceScale
state.p = p
state.convertedDegrees = convertedDegrees
state.updateNeeded = true
thermostatMode
private getStandardDelay()
1000
def updateIfNeeded()
def cmds = []
// Only ask for battery if we haven't had a BatteryReport in a while
if (!state.lastbatt || (new Date().time) - state.lastbatt > 24*60*60*1000)
log.debug "Getting battery state"
cmds << zwave.batteryV1.batteryGet().format()
if (state.refreshNeeded)
log.debug "Refresh"
cmds << zwave.sensorMultilevelV1.sensorMultilevelGet().format() // current temperature
cmds << zwave.thermostatSetpointV1.thermostatSetpointGet(setpointType: physicalgraph.zwave.commands.thermostatsetpointv1.ThermostatSetpointSet.SETPOINT_TYPE_HEATING_1).format()
cmds << zwave.thermostatModeV1.thermostatModeGet().format()
cmds << zwave.thermostatOperatingStateV1.thermostatOperatingStateGet().format()
cmds << zwave.thermostatModeV1.thermostatModeSupportedGet().format()
state.refreshNeeded = false
if (state.updateNeeded)
log.debug "Update"
cmds << zwave.thermostatSetpointV1.thermostatSetpointSet(setpointType: physicalgraph.zwave.commands.thermostatsetpointv1.ThermostatSetpointSet.SETPOINT_TYPE_HEATING_1, scale: state.deviceScale, precision: state.p, scaledValue: state.convertedDegrees).format()
state.updateNeeded = false
if (state.configNeeded)
log.debug "Config"
state.configNeeded = false
// Nodes controlled by Thermostat Mode Set - not sure this is needed?
cmds << zwave.associationV1.associationSet(groupingIdentifier:1, nodeId:[zwaveHubNodeId]).format()
// Set hub to get battery reports / warnings
cmds << zwave.associationV1.associationSet(groupingIdentifier:3, nodeId:[zwaveHubNodeId]).format()
// Set hub to get set point reports
cmds << zwave.associationV1.associationSet(groupingIdentifier:4, nodeId:[zwaveHubNodeId]).format()
// Set hub to get multi-level sensor reports (defaults to temperature changes of > 1C)
cmds << zwave.associationV1.associationSet(groupingIdentifier:5, nodeId:[zwaveHubNodeId]).format()
// set the temperature sensor On
cmds << zwave.configurationV1.configurationSet(configurationValue: [0xff], parameterNumber: 1, size: 1).format()
log.debug "association $state.association user: $userAssociatedDevice"
int nodeID = getAssociatedId(state.association)
// If user has changed the switch association, send the new assocation to the device
if (nodeID != -1)
log.debug "Setting associated device $nodeID"
cmds << zwave.associationV1.associationSet(groupingIdentifier: 2, nodeId: nodeID).format()
def userWake = getUserWakeUp(userWakeUpInterval)
// If user has changed userWakeUpInterval, send the new interval to the device
if (state.wakeUpInterval != userWake)
state.wakeUpInterval = userWake
log.debug "Setting New WakeUp Interval to: " + state.wakeUpInterval
cmds << zwave.wakeUpV2.wakeUpIntervalSet(seconds:state.wakeUpInterval, nodeid:zwaveHubNodeId).format()
cmds << zwave.wakeUpV2.wakeUpIntervalGet().format()
if (cmds.size() > 0)
cmds << "delay 2000"
cmds
private getUserWakeUp(userWake)
if (!userWake)
userWake = â3600â // set default 1 hr if no user preference
// make sure user setting is within valid range for device
if (userWake.toInteger() < 60)
userWake = â600â // 10 minutes - Mininum
if (userWake.toInteger() > 36000)
userWake = â36000â // 10 hours - Maximum
return userWake.toInteger()
// Get the Z-Wave Id of the binary switch the user wants the thermostat to control
// -1 if no association set
int getAssociatedId(association)
int associatedState = -1
int associatedUser = -1
log.debug "getAssociatedId $association"
if (association != null && association != ââ)
associatedState = association.toInteger()
log.debug âState $association $associatedStateâ
if (userAssociatedDevice != null && userAssociatedDevice != ââ)
try
associatedUser = Integer.parseInt(userAssociatedDevice, 16)
catch (Exception e)
log.debug âuserDev $userAssociatedDevice $associatedUserâ
// Use the app associated switch id if it exists, otherwise the device preference
return associatedState != -1 ? associatedState : associatedUser
// Called from the SRT321 App with the Z-Wave switch network ID
// How long before SmartThings realises that having device preferences
// with input â*â âcapability.switchâ is reasonable???
void setupDevice(value)
state.association = "$value"
int val = Integer.parseInt(value)
String hex = Integer.toHexString(val)
log.debug "Setting associated device Id $value Hex $hex"
settings.userAssociatedDevice = hex
/* SRT321 Helper App */
definition(
author: âMeavyDevâ,
description: âAssociates the SRT321 with a switchâ,
category: âMy Appsâ,
iconUrl: âhttps://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.pngâ,
iconX2Url: âhttps://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.pngâ)
preferences
input âassociatedSwitchâ, âcapability.switchâ, title: âSwitch?â, multiple: false, required: true
input âthermostatSelectedâ, âcapability.thermostatâ, title: âSRT321 Thermostat?â, multiple: false, required: true
def installed()
def networkId = " â+associatedSwitch.deviceNetworkId+â â
def devId = Integer.parseInt(networkId.replaceAll(â ", ââ), 16)
log.debug "Installed - Id $devId"
state.association = devId
runIn(1, handler)
def updated()
log.debug "Updated - Id $devId"
state.association = devId.toString()
runIn(1, handler)
// No real need for a handler, but this was avoiding crashes
// Send the âDevice Network Idâ to the SRT321 thermostat so it can control the switch
def handler()
log.debug âSetting thermostat associationâ
thermostatSelected.setupDevice(state.association)
