Right. For those that do not know what this is. it is a Switch built for immersion heaters but I’m sure could control other things. it has a hard button on it for turning on for 30, 60 and 120 mins before auto turning off. It looks to have a bit more available to it when z-wave active.
Some features:
- 1min to 24 hours time
- Auto turn off at Temp
- Tank Temp reading.
Taken a bit of time to learn what I’m doing and how to do it but I’m getting there. Attached is the most up-to-date code that works for this item.
At the moment all it does is report the temp and the on and off switch function
Things to do
- Check Temp of water matches tank reading
- Build in a calibration line for other users
- Create 30, 60, 120 and 240 and ALL DAY Button on to Handler
- Create Smart app to handle setting custom schedules (Possibly)
- Confirm Configurations are working and Reportable
- Tidy up code
CODE
- Thanks to MeavyDev for his SRT321 code that helped me make this work.
metadata {
definition (name: “Secure SIR321”, namespace: “Behold81”, author: “Ant Pugh”) {
capability “Actuator”
capability “Configuration”
capability “Switch”
capability “Polling”
capability “Refresh”
capability “Sensor”
capability “Thermostat Schedule”
capability “Temperature Measurement”
fingerprint deviceId:"0x1000", inClusters: "0x72 0x86 0x25 0x20 0x85 0x53 0x70 0x31"
// simulator metadata
simulator {
status “on”: “command: 2003, payload: FF”
status “off”: “command: 2003, payload: 00”
// reply messages reply "2001FF,delay 100,2502": "command: 2503, payload: FF" reply "200100,delay 100,2502": "command: 2503, payload: 00"
// tile definitions
tiles(scale: 2) {
multiAttributeTile(name:“switch”, type: “lighting”, width: 6, height: 4, canChangeIcon: true){
tileAttribute (“device.switch”, key: “PRIMARY_CONTROL”) {
attributeState “on”, label: ‘Heating’, action: “switch.off”, icon: “st.Bath.bath4.on”, backgroundColor: “#79b821”
attributeState “off”, label: ‘${name}’, action: “switch.on”, icon: “st.Bath.bath4.off”, backgroundColor: “#ffffff”
tileAttribute(“device.temperature”, key: “SECONDARY_CONTROL”)
attributeState(“default”, label:‘${currentValue} C’, unit:“C”)
}standardTile("refresh", "device.switch", width: 2, height: 2, inactiveLabel: false, decoration: "flat") { state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh" } main "switch" details(["switch","temperature","refresh"])
log.debug “parse description: $description”
def result
def cmd = zwave.parse(description, [0x20:1, 0x25:1, 0x86:1, 0x70:1, 0x72:1, 0x31:1, 0x53:1, 0x86:1])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
if (result?.name == ‘hail’ && hubFirmwareLessThan(“000.011.00602”)) {
result = [result, response(zwave.basicV1.basicGet())]
log.debug “Was hailed: requesting state update”
} else {
log.debug “Parse returned ${result?.descriptionText}”
return result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
def result =
result << createevent(name: “switch”, value: cmd.value ? “on” : “off”)
result
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
[name: “switch”, value: cmd.value ? “on” : “off”, type: “physical”]
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
[name: “switch”, value: cmd.value ? “on” : “off”, type: “digital”]
def zwaveEvent(physicalgraph.zwave.commands.hailv1.Hail cmd) {
[name: “hail”, value: “hail”, descriptionText: “Switch button was pressed”, displayed: false]
def zwaveEvent(physicalgraph.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
if (state.manufacturer != cmd.manufacturerName) {
updateDataValue(“manufacturer”, cmd.manufacturerName)
def zwaveEvent(physicalgraph.zwave.commands.sensormultilevelv1.SensorMultilevelReport cmd)
def result =
def map = [:]
map.value = cmd.scaledSensorValue.toString()
map.unit = cmd.scale == 1 ? “F” : “C”
map.name = “temperature”
createEvent(map)
// Handles all Z-Wave commands we aren’t interested in
def on() {
delayBetween([
zwave.basicV1.basicSet(value: 0xFF).format(),
zwave.switchBinaryV1.switchBinaryGet().format()
def off() {
delayBetween([
zwave.basicV1.basicSet(value: 0x00).format(),
def poll() {
delayBetween([
zwave.switchBinaryV1.switchBinaryGet().format(),
zwave.manufacturerSpecificV1.manufacturerSpecificGet().format(),
zwave.sensorMultilevelV1.sensorMultilevelGet().format()
def refresh() {
delayBetween([
def configure()
log.debug “configure”
// Normally this won't do anything as the thermostat is asleep, // but do this in case it helps with the initial config
//Set Temp Scale
zwave.configurationV1.configurationSet(configurationValue: [0xff], parameterNumber: 2, size: 1).format()
//Setup Group 2
zwave.associationV1.associationSet(groupingIdentifier:2, nodeId:[zwaveHubNodeId]).format()
//Set Report Time
zwave.configurationV1.configurationSet(configurationValue: [0x3c], parameterNumber: 3, size: 2).format()
zwave.configurationV1.configurationSet(configurationValue: [0x3c], parameterNumber: 4, size: 2).format()
zwave.configurationV1.configurationSet(configurationValue: [0x12c], parameterNumber: 5, size: 2).format()
