This app looks very interesting as I want to move away from SHM, because it is so unreliable.
Is there a step by step to get this working? I have created apps in the ide before, but just want to make sure I am doing everything correctly.
This is both an app and a device type. Post t us the closet
Just installed both (IOS Version) and have a couple questions. Can i make the notifier my dashboard? Can I control things (disarmed, armed stay, armed away) from the notifier or is it purely just to see what is happening or the status? Last, I have the main screen and the system is armed stay but it is not showing up with any light behind armed stay.
Alright, so I updated my notification options in Smart Alarm and when I open the notifier i get a brief green dot behind the green status but it doesnāt stay illuminated. I read you talking about it in earlier posts, just wasnāt sure if it was fixed.
Date Source Type Name Value User Displayed Text
2016-04-12 12:25:23.792 AM MST
moments ago APP_COMMAND deviceNotification
2016-04-12 12:25:21.754 AM MST
2016-04-12 12:25:19.696 AM MST
moments ago DEVICE armDisarm lite A Smart Alarm Device Notifier arm disarm is lite
2016-04-12 12:25:17.262 AM MST
2016-04-12 12:11:27.691 AM MST
16 minutes ago APP_COMMAND deviceNotification
2016-04-12 12:11:27.508 AM MST
16 minutes ago DEVICE statusText Armed - Stay A Smart Alarm Device Notifier status text is Armed - Stay
2016-04-12 12:11:27.495 AM MST
16 minutes ago DEVICE armStay lite A Smart Alarm Device Notifier arm stay is lite
2016-04-12 12:09:15.824 AM MST
18 minutes ago DEVICE armStay unlite A Smart Alarm Device Notifier arm stay is unlite
2016-04-12 12:07:15.360 AM MST
20 minutes ago DEVICE statusText Armed - Stay Smart Alarm Device Notifier status text is Armed - Stay
2016-04-12 12:07:15.346 AM MST
20 minutes ago DEVICE armStay lite Smart Alarm Device Notifier arm stay is lite
2016-04-12 12:07:15.321 AM MST
20 minutes ago DEVICE armStatus Armed - Stay Smart Alarm Device Notifier arm status is Armed - Stay
2016-04-12 12:07:15.295 AM MST
20 minutes ago APP_COMMAND deviceNotification
2016-04-12 12:05:57.773 AM MST
22 minutes ago DEVICE armStay unlite Smart Alarm Device Notifier arm stay is unlite
2016-04-12 12:05:57.756 AM MST
22 minutes ago DEVICE statusText Unknown Smart Alarm Device Notifier status text is Unknown
2016-04-12 12:05:28.316 AM MST
22 minutes ago DEVICE statusText Armed - Stay Smart Alarm Device Notifier status text is Armed - Stay
2016-04-12 12:05:28.297 AM MST
22 minutes ago DEVICE armStay lite Smart Alarm Device Notifier arm stay is lite
2016-04-12 12:05:26.278 AM MST
22 minutes ago DEVICE armDisarm unlite Smart Alarm Device Notifier arm disarm is unlite
2016-04-12 12:05:24.027 AM MST
22 minutes ago APP_COMMAND deviceNotification
2016-04-12 12:05:21.773 AM MST
2016-04-12 12:04:38.658 AM MST
23 minutes ago APP_COMMAND deviceNotification
2016-04-12 12:04:36.454 AM MST
23 minutes ago DEVICE armDisarm lite Smart Alarm Device Notifier arm disarm is lite
2016-04-12 12:04:34.436 AM MST
23 minutes ago DEVICE armStatus Disarmed Smart Alarm Device Notifier arm status is Disarmed
2016-04-12 12:04:34.410 AM MST
2016-04-11 11:50:35.593 PM MST
37 minutes ago DEVICE armAway unlite Smart Alarm Device Notifier arm away is unlite
2016-04-11 11:50:35.580 PM MST
37 minutes ago DEVICE armStay unlite Smart Alarm Device Notifier arm stay is unlite
2016-04-11 11:50:35.567 PM MST
37 minutes ago DEVICE armDisarm unlite Smart Alarm Device Notifier arm disarm is unlite
2016-04-11 11:50:35.555 PM MST
37 minutes ago DEVICE statusText Unknown Smart Alarm Device Notifier status text is Unknown
2016-04-11 11:50:35.542 PM MST
37 minutes ago DEVICE armStatus Unknown Smart Alarm Device Notifier arm status is Unknown
2016-04-11 11:50:35.529 PM MST
37 minutes ago DEVICE lastAlertType None Smart Alarm Device Notifier last alert type is None
2016-04-11 11:50:35.514 PM MST
37 minutes ago DEVICE lastAlert None Smart Alarm Device Notifier last alert is None
2016-04-11 11:50:35.329 PM MST
37 minutes ago DEVICE status All Ok Smart Alarm Device Notifier status is All Ok
make sure to use the ios version of the device type
how do you know where to keep up with updates on these apps? i searched and found numerous threads. turns out i had code installed that showed last modification of like 7/15. i had to reinstall just to get it to recognize additional sensors. you could select them in the configuration but when you looked at the app status up top it did not show them. very odd. even devices showed in ide to be included in app. anyway i reinstalled and until that issue it was all working fine. how can i keep tabs on updates?
thanks
Not sure what you mean. If you donāt install my version of smart alarm and this device type it will not work.
Thank you Larry. So far so good. Itād be nice if I could chime my keypads while the 30 second exit delay was happening.
Iām out of town skiing for a week. Do you have code that can do that. I
nice. have fun!
im currently using the Iris keypad (https://www.amazon.com/Iris-Smart-Home-Management-3405-L1/dp/B01GCKAFX8/ref=pd_lpo_421_tr_img_3?_encoding=UTF8&psc=1&refRID=YPTHGJBSDYJ3G5H4TW98) which works really well. There are buttons for Off/On/Partial which using the 3400-X device handler lets me map those buttons to my routines which just changes the mode to home/away/stay and the Smart Home Monitor to disarmed/armed away/armed home.
I thought i saw somewhere in another thread a chime function for the keypad so i will try to find it. Thanks again for all your help.
apparently its code in smart alarm that does it.
Updates for SmartAlarm:
- Chime support! (Add your keypads to the āChime Devicesā list in the āNotificationsā page to get chimes to work)
heres the code for the version of smart alarm that has Chime code.
https://github.com/miriad/SmartThingsPublic/blob/SmartAlarm-Keypad/smartapps/statusbits/smart-alarm.src/smart-alarm.groovy
@Lgkahn Hello, I am using your version of Smart Alarm. I had a question, everytime I activate the alarm, my hue bulbs turn off, any way to stop that from happening?
it should only tturn off any lights that are set to go off to signal an alert⦠if you dont want this feature remove those lights from the settings.
No, I want the feature, The issue is if I am in my living room and watching TV and I active the alarm, the lights turn off. Just trying to stop that. I want them to turn on with color when there is an alarm. Any other suggestions?
