I have tired to use Zwave twiker.
The parameter are as per default as online manuals.
Clamp paramenter is strange: “-1” only 0,1, 255 (0xFF) are valid, I’ll try to reverse the clamp but I have already done it.
Also Parameter 9: Enable_CRC16 is not default, Default Value: 1 zwave twiker read 0
I have tried to change some parameters, all but Parameter 9: Enable_CRC16 can be changed by nothing happen.
Command types [8]:
Command: [commandClassId: 0x32, commandClassName: METER, commandID: 0x02, description: zw device: 09, command: 3202, payload: 81 4A 00 00 00 00 00 00 ]
=> Example: MeterReport(scale2: false, scale: 5, rateType: 0, precision: 2, meterValue: [0, 0], deltaTime: 0, meterType: 1, size: 2, scaledPreviousMeterValue: 0.00, scaledMeterValue: 0.00, previousMeterValue: [0, 0])
Command: [commandClassId: 0x59, commandClassName: ASSOCIATION_GRP_INFO, commandID: 0x02, description: zw device: 09, command: 5902, payload: 09 05 05 01 11 28 0E ]
=> Example: AssociationGroupNameReport(lengthOfName: 5, name: [5, 1, 17, 40, 14], groupingIdentifier: 9)
Command: [commandClassId: 0x70, commandClassName: CONFIGURATION, commandID: 0x06, description: zw device: 09, command: 7006, payload: 03 01 06 ]
=> Example: ConfigurationReport(parameterNumber: 3, scaledConfigurationValue: 6, reserved11: 0, size: 1, configurationValue: [6])
Command: [commandClassId: 0x72, commandClassName: MANUFACTURER_SPECIFIC, commandID: 0x05, description: zw device: 09, command: 7205, payload: 03 01 00 48 01 0F ]
=> Example: ManufacturerSpecificReport(productTypeId: 72, manufacturerId: 769, manufacturerName: null, productId: 271)
Command: [commandClassId: 0x73, commandClassName: POWERLEVEL, commandID: 0x03, description: zw device: 09, command: 7303, payload: 00 00 ]
=> Example: PowerlevelReport(powerLevel: 0, timeout: 0)
Parameter #0: [id:0, scaledConfigurationValue:0, size:1]
Parameter #1: [id:1, scaledConfigurationValue:1, size:2]
Parameter #2: [id:2, scaledConfigurationValue:30, size:1]
Parameter #3: [id:3, scaledConfigurationValue:6, size:1]
Parameter #4: [id:4, scaledConfigurationValue:4, size:1]
Parameter #5: [id:5, scaledConfigurationValue:10, size:2]
Parameter #6: [id:6, scaledConfigurationValue:10, size:2]
Parameter #7: [id:7, scaledConfigurationValue:0, size:1]
Parameter #8: [id:8, scaledConfigurationValue:-1, size:1]
Parameter #9: [id:9, scaledConfigurationValue:0, size:1]
Parameter #10: [id:10, scaledConfigurationValue:0, size:1]
Parameter #11: [id:11, scaledConfigurationValue:0, size:1]
Parameter #12: [id:12, scaledConfigurationValue:0, size:1]
Parameter #13: [id:13, scaledConfigurationValue:0, size:1]
Parameter #14: [id:14, scaledConfigurationValue:0, size:1]
Parameter #15: [id:15, scaledConfigurationValue:0, size:1]
Parameter #16: [id:16, scaledConfigurationValue:0, size:1]
Parameter #17: [id:17, scaledConfigurationValue:0, size:1]
Parameter #18: [id:18, scaledConfigurationValue:0, size:1]
Parameter #19: [id:19, scaledConfigurationValue:0, size:1]
a39905ce-ee49-4058-98d2-d0bec342ed64 13:22:48: info SensorMultilevelReport types [0]:
a39905ce-ee49-4058-98d2-d0bec342ed64 13:22:39: info New meter report: Instantaneous Current: 0.00 A
a39905ce-ee49-4058-98d2-d0bec342ed64 13:22:38: info New meter report: Instantaneous Voltage: 0.0 V
a39905ce-ee49-4058-98d2-d0bec342ed64 13:22:36: info New meter report: Instantaneous Power: 0.0 W
