Schlage ZWave+ Guest Access Service Broken
I have a Schlage BE469BP that has been working with the “Guest Access” service for years.
Recently the “Guest Access” service stopped working and would just endlessly “spin” when attempting to set/show guest access codes.
A band-aide fix is to remove the SmartThings “Guest Access” service and then reinstall it again.
When I do this, the “Guest Access” set/show codes feature will work exactly ONCE but then will lock up again on the very next attempt to use the “Guest Access” feature.
Any ideas ??
Thanks for any help on this one.
It is odd because I changed nothing from when it used to reliably work.
