Schlage Connect - Which hub for my office?
When you say hub, what do you mean?
The hub is only a channel for communication with the lock. What features are available to use on your lock depends on what device handler is being used by the hub when communicating with your lock (I’m over simplifying this).
If you’re using the stock (build in) ST device handler then you’ll have the ability to lock and unlock.
If you want to use the advanced features of your lock like the alarms, auto lock, enabling/disabling keypad etc you will need to install and use a custom device handler.
Here is an examples of a custom device handler that allows you to use the advanced features of your Schlage connect lock (you’ll need access to RBoy Apps to use this one).
