Same issue here. We have had this keypad for at least 2 years, suddenly (yesterday) it stopped responding. A quick power cycle and it came back to life. Then a couple hours later, it was dead again. Tried brand new batteries (even though the last ones were at 83%), same thing, came back to life but only temporarily. Called Schlage, because we were within our warranty - they replaced the lock. Hooray!
Did anyone get return directions with their replacement lock? I just got mine yesterday, but no directions or return label. Or are they taking the Amazon approach of discard the old one. I emailed them back, but it seems like a 3-4 day wait period for a reply.
I have 3 of these and have the same issue with just one of them. I called Schlage and they’ve sent a replacement but I have a theory of what may be causing this to happen and was hoping everyone could confirm there instances against my theory. Of the 3 locks I have installed, 2 are located behind a store door while the 3rd lock (with the problems) is mounted on a door without a storm door. I live in MI where summers get hot and winters get cold so my theory is that because this lock is exposed to the elements and not covered by a storm door the rain, snow, hot & cold is somehow effecting the function of the keypad? So I’m curious if your problem locks are exposed to the elements, covered by a storm door or under a roof such as inside of a garage/under a porch eave?
RBoy
45
We’ve got a few test locks setup in different conditions including this one facing the morning/afternoon sun outside with limited exposure to rain and frost for the past 6 years. So far so good.
A few things to check:
Is the keypad wire connected properly. You’ll have to disassemble the mounting and check it.
So i had this issue. Locked/unlocked via phone, key worked alarm etc, but the exterior keypad looked dead. Removing/replacing the batteries didnt do anything and the wires between interior and exterior were fine and connected. I took it apart and noticed moisture on the circuit board and corrosion on the inside of interior plate. So i took it all the way apart, (removed the circuit board) and wiped it off with a clean paper towel. I Think the water droplets on the board made the keypad invisible because once i wiped it off (it had a decent amount of water buildup) it worked just fine. I live in the south and with the hurricane elsa just went through i think the difference between the 90deg 80%+ humidity outside and the cooler inside caused the condensation to happen. So maybe give the circuit board a quick wipe down and see it it work (both sides).
I have two BE469ZPs; firmware 0.11.0. They both do it with brand new batteries. The first one about 3 days after installation, the 2nd one 27 minutes after installation. Put voltage meter on them both: 6.4V and 6.47V respectively. First one is connected to my Aeotec SmartHub and still works via the app when the keypad is dead. 2nd won’t connect to the hub/mesh even though it’s 50ft line-of-sight to the first lock; 70 ft to hub. (So much for robust z-wave meshes). Disconnecting / reconnecting batteries “solves” it…
UPDATE: Just spoke with Kim at Schlage CS and received some useful info: They recently switched chip vendors because Ford was also a customer of their older chips and post-COVID, Schlage had severe availability issues. They have a number of reports of this problem and apparently, based on the date of mfg (which is on the programming code sticker), the problem is only occurring with the new chips. FYI: My dates of mfg are: 8/3/2022 and 8/8/2022. So, they are sending me two new locks that have the old chip in them. We’ll see…
I am a Home Assistant user, but stumbled upon this thread because I am having this issue with my new BE469ZP (Z Wave). The keypad is dying, but the deadbolt can still be controlled thru Home Assistant (remotely). The keypad comes back to life for a few hours with a battery disconnect/reconnect.
I switched from the Schlage Encode (Wi-Fi). The Schlage encode never had any keypad issues, and the keypad had a much better touch screen user interface. I feel like I’ve downgraded my deadbolt. Shame on Schlage for acknowledging, but not pulling these from the shelves / recall.
For whatever it’s worth, I have the same problem and each time I complain to Schlage about this, it always comes down to them sending me another lock. I’m on my third lock.
I hate to necro a thread, but this just happened to 2 of my locks. The answer: humidity. They were full of water. 102 degrees outside, 70 degrees inside. Locks dead
RBoy
57
Maybe consider Yale. I’ve found them more durable even in extreme weather.
I came here looking to resolve this issue - I was thinking maybe the cable from the pad had come loose as @GoulyONE suggested. when I took it apart I just happened to noticed that one of the prongs of the battery’s female snap connector was bent inward. I think this was just enough to cause the keypad to intermittently loose power. I bent the prong back with an eyeglass screwdriver - we will see if that resolves the issue.
Try checking the batteries first, and maybe give the lock a reset. Make sure it’s close enough to the z-wave network. Fingers crossed one of these helps get it back up and running.
Just a heads up. I have the Encode lock and I have the same issue. Last night, worked fine. Went to bed and this morning batteries were dead. Ok, that happens. Replaced the batteries and now the keypad is dead. Lock works fine thru the app. Reset it 3-4 times and that works. Interesting is that when I do the factory reset via the button, the LEDs do not light up on the inside rear. No red, no blue (in programming mode). So the led isnt getting power. Or the keypad. But the lock mechanism does and works. Replaced batteries twice. Same issue. Called Schlage. Chose the option to have them call me back (I was 14th in line). 6 hours later, still waiting for the call. Called back and I’m 30th in line. Been on hold for over an hour. So you lucky people that actually got ahold of Schlage, congrats. Looks like that was all pre Covid. They don’t seem to have customer service folks manning the phones anymore.
