I’m unclear if by using the SmartThings hub if I can change the remote code to enter the door. I’d like to integrate it into the SmartHub, but if I have to use some other application to change the code, I’m ok with that too. I’m just not clear what Schlage will do with ST and what it won’t do.
Not enough information – such as which lock you have. However, if it supports code and code changing via z-wave, there’s a “user management” tool by @RBoy floating around that can be used. It works.
