Samsung Smart TVs now show up in the SmartThings UK Marketplace. You should be able to add it under “Televisions”. We’re working through some kinks with this integration, so please contact support if you run into any issues.
If you don’t see it in the Marketplace please give it up to 24 hours to pop up.
Can we do other things with the handler such as change channels and set inputs etc? I would really love to see what else we can do with this now that it is working?
Im struggling to add mine. It wont discover the tv. I’ve left it for 10mins and still nothing. Is there anything special you did to get it to discover?
Hi all.
Some buttons like “Source” do not perform what is expected: Being able to select the input source (tv, hdmi1,etc.).
Is there any API reference to map to the correct button/command?
I have UE40es7000
[Update]
Found a few issues with the device handler…related with Source and HDMI…
Copyright 2015 SmartThings
Licensed under the Apache License, Version 2.0 (the “License”); you may not use this file except
in compliance with the License. You may obtain a copy of the License at:
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
on an “AS IS” BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
for the specific language governing permissions and limitations under the License.
Now i am trying to user Core to select the correct HDMI source…no matter what I use (string…number) as parameter nothing works.
Anyone is selecting the source calling the HDMI() function?
Hi @Sergio_Ferreira,
I’m sorry, but your TV seems to be a 2012 model…
For this connection/link between TV and smartthings discussed in this topic, you’ll need a KU or a KS modell (2016), series 6 and upwards.
However, if my memory serves me correct, there is a opportunity to get some degree of control through the ip socket method.
I don’t have any topic regarding this in mind, but I’m sure you will find it through a search on the forum
