I have 3 samsung TVs on my network, recently they’ve all started showing the incorrect state in the logs, which is causing nightmares with some of my automation (I switch inputs on my amp, based on whether the TV is on or not). Basically, it’s reporting that the TV is offline, even though I’m sat here watching it, and watching netflix, so it’s definitely connected to the internet.
All of the TVs are on the latest software version and my hub is on 17.12. I think this has started happening since the last hub upgrade, but I can’t be sure.
Anyone else had similar problems / have a solution? I’ve tried removing and adding the TVs to see if that helps, but no luck.
Any help would be greatly appreciated.
