The DTH provided by Samsung has major problems, as well as the IOS app. Here is a list of the problems found.
- The Speaker DTH refuses to keep the volume setting.
- When you try to increase the setting in the DTH Config by using the slider and you move it up and select you setting, there isn’t a problem. But when you try to tap the X in the top right corner it doesn’t respond. After 10 or so taps it closes, but the setting is not kept at least 99% of the time. it goes back to the setting that it choose all on its own.
This is annoying to say the least. Anyone else have this problem on IOS if so please let me know so I can place a bug report.
