Samsung led tv 40 ue40h6410
Hello toghether,
I know that older Smart TV ‘s can’t be connected to Smartthings. I have an 2014 samsung led tv 40 ue40h6410. It works still perfekt and in the moment I have integrated this TV with a Switch Bot IR blaster. In my Home Assistant instsllstion this TV was discoverd directly. So I was asking myself , maybe I can add it to Smartthings in a better way. Is there maybe a chance for writing an Edge Driver or somethibg like that ? Thank you
Have you tried setting your Home Assistant as a Matter Bridge. Then try to bring it into ST. :person_shrugging:
This was a good and interessting idea. The first part worked. Smartthings discoverd the Bridge and found the TV. But I could only controll the volume, not more. But I will have a closer look at this
There are at least 2 ways to use Matter to bring devices from HA to ST see the following.
