Anyone already received the firmware update? Is it working fine? Im still waiting for my hub to get updated
negative. Still 0.38
Me too i still doesnāt receive it⦠waiting for it⦠@nayelyz is there a way we can force the update ? or ask engineering team to force update for some users as me whoās request for it nowā¦
Thanks.
Thanks @nayelyz i finally get the update and already install few edge drivers⦠I will test everything in the next day!!!
I really hope Samsung Team bring back wifi hub ln the roadmap support and future development release like on v3 hub or aeotec who received frequently update hope wifi hub also received same release update frequentlyā¦
Nayelyz >>>> Is Samsung team will continue to work on future firmware release for this wifi hub ??? Thanks to let us know ?? @nayelyz
Great! Thanks for letting us know, weāll be around in case you have any questions. Please, it would be awesome if you could post them in a new thread so this one is only related to the firmware release.
AFAIK, this update took a long time to be released because it required a lot of effort from the team, to make Edge available on this kind of device, not because they werenāt worth it (eg. if the support would stop)
In case the support of any device/integration will stop, the team will make a big announcement about it and with enough time to take action (something similar to the Groovy sunset), so donāt worry.
thanks @nayelyz for you fast reply⦠about future update iām not worried about the end of support if we have something as same performance that can be replace wifi hub⦠the new aeotec actual hub is not so good⦠nothing even the new aeoctec hub is not good as the WIFI one who integrate MESH systemā¦
if one day you will no longer support Wifi Hub hope you will release something like it as MESH system no as aeotec single, simple hub bridge⦠compare to many of HUB we can have with Wifi Hub⦠FYI for my self i just have 10 WIFI HUB (many of it i buy as second hand used one)⦠i know 10 is probably overkill and FYI not all are connected (some are in the box)⦠cause my house is pretty big but itās not CASTLE!! so with Wifi Hub the only option of your HUB who support MESH System i donāt know why Aeotec release Hub without MESH integrationā¦
Single point of HUB without MESH system is so OLD SCHOOL like 2015-2020⦠future is on MESH system network⦠so as i said i donāt worry about end support Wifi Hub and be advise long time before ⦠but no other option are currently available to get same performance even the last aeotec oneā¦
So really thanks to consider future developpement for wifi hub or work with aeotec or any other brand to release new smartthings WITH *MESH system ON⦠as the same as the wifi hub itāsā¦
This is highly subjective. I would wager most users on this forum prefer their wifi mesh system to be separate from their smart home hub, so they would consider SmartThings wifi as inferior to the regular Aeotec hub. Z-wave and zigbee form mesh networks on their own, so baking it into a wifi router doesnāt give much advantage. From the z-wave perspective, a light switch is just as good a z-wave network node as a wifi router.
Everything is moving to Thread ultimately, with announcement of 1.3 today, everything will be interoperable including the border routers:
I think of the SmartThings WiFi hubs as an embarrassing incident in SmartThings past that it is best we allow them to quietly forget about.
11 posts were split to a new topic: [Edge drivers] Issue with the logcat and driver installation
And for model ET-WV520 models?
I have 2 ET-WV520 in the Office and 3 ET-WV525 in my Home.
I believe that my ET-WV520 are updated!
However, my ET-WV525 are not showing it data in Groovy or in the App. It is not showing even Home Monitor information in the App. I tried ST Support (1378955), they asked lots of procedures, that I did and sent them back logs⦠but after this (Suchitra did not answer anything).
I am sure that my hub will not update until ST Support solve this fail in my ST Wifi hub.
Same problem here in my 525. In Groovy website no information is also available for the hub. I believe that ST Hub will be not able to receive any update in this situation.
Did you check if you had similar menus to the other models? If the device is faulty or offline, you might not see all the menus.
Yes, they should be able to guide you better, it seems yours is a particular issue, unfortunately, I donāt have the same permissions as them so, I cannot help you further.
Donāt worry, if this is the case, they should help you after solving the issue or at least redirect you to the corresponding team, just let them know your concerns so they are aware.
I got the update, so I guess Iāll try adding an edge device today and see what happens
Hi to you @nayelyz since last update I canāt no longer add more device⦠I receive error message says, we canāt add more than 200 devices⦠Why??? could you help to fix that!! Thanks you.
Iām on Android
And, have you already reached out this limit? All devices are considered including the virtual ones.
Can we please get this limit increased? Iām also practically at this limit.
