Samsung Connect Home Pro Issues
I have 3 peered Samsung Connect Home Pro devices. This weekend, both devices when offline and would not re-sync to the primary router. I was able to remove and reset 1 of the two slave devices. The second slave now seems to be bricked. When booting, the following light sequence occurs.
Blue/Green (fast) -> Green Steady -> Blue/Green (fast) -> Green Steady -> Green flash 3 times -> Light goes off.
The device will re-attempt this light sequence 3 or 4 times before the light just permanently stays off.
I’ve tried to use the reset button to no avail.
Is this thing bricked?
Apparently there is no solution. Samsung is RMA’ing the unit.
