Samsung CAC air conditioners (DA-AC-CAC-01001) report temperature in C while RAC units on the same location report F
I have eight Samsung AC units on one SmartThings location. Six are
residential (DA-AC-RAC-01001), two are light-commercial cassettes
(DA-AC-CAC-01001). The location temperatureScale is F. The RAC units
display F. The CAC units display C, and I can find no way to change it.
Equipment: AM024FE1DCG/AA indoor units, MWR-WG01UN wired controllers,
integral Wi-Fi (no separate MIM adapter). The wall controllers
themselves display F correctly.
API comparison, same account, same location, taken minutes apart:
CAC (DA-AC-CAC-01001, micom 10241942)
temperatureMeasurement.temperature 23 unit C
thermostatCoolingSetpoint.coolingSetpoint 23.3 unit C
coolingSetpointRange min 18 max 30 step 0.5 unit C
RAC (DA-AC-RAC-01001, micom 10269441)
temperatureMeasurement.temperature 73 unit F
thermostatCoolingSetpoint.coolingSetpoint 74 unit F
coolingSetpointRange min 61 max 86 step 1 unit F
What I’ve already ruled out:
  • Location temperatureScale is F and every RAC device honors it.
  • Both profiles return releaseCountry: null, so it isn’t region
    provisioning.
  • Both ship WW-SKU Wi-Fi modules (CAC: ASA-WW-TP1-24-PACCOM,
    RAC: ARA-WW-TP1-24-ARXX00).
  • Neither profile exposes any temperature-unit capability.
  • Nothing unit-related appears in the CAC unit’s
    custom.disabledCapabilities or samsungce.unavailableCapabilities,
    so it isn’t a hidden/suppressed control.
  • Firmware is current: newVersionAvailable false, availableModules
    empty.
  • Samsung HVAC TB20-0019 documents a “Temp unit” C-to-F control for
    MIM-04U / MIM-H05UN adapters. There’s no equivalent for
    integral-Wi-Fi CAC indoor units.
Note the CAC coolingSetpoint of 23.3 against a declared 0.5 step —
that’s 74F converted, so the connector is storing the C conversion of
an F setpoint made at the wall controller.
Questions: is F display supported at all on DA-AC-CAC-01001? If the
unit is fixed in the profile, is there a path to getting it changed,
or a supported workaround short of a virtual device mirroring a
converted value?
