To answer your question — on the freezer (TP2X_REF_DACOR_20K), the samsungce.sabbathMode capability does appear in the Advanced web UI with on and off commands listed. However pressing either button returns: “Error running command ‘on’. 422 response code is NOT_FOUND”. The capability is also explicitly listed in custom.disabledCapabilities in the device status JSON.
On the refrigerator (TP6X_REF_16K), the sabbath mode capability doesn’t appear at all — not in the Advanced web UI and not in the SmartThings mobile app.
Neither device shows Sabbath Mode anywhere in the SmartThings mobile app UI, so this is not accessible through any app capability or settings menu. The only way to activate it is via the physical button sequence on the panel.
Samsung’s own support page states: “Models which have both Sabbath mode and SmartThings can turn Sabbath mode on or off in SmartThings” — so Samsung explicitly documents this as a supported feature. The only difference between our Dacor units and the Samsung models where it works is the disabledCapabilities flag in the device profile.
I’ve already contacted Samsung/Dacor support directly. Is there a specific escalation path or team at Samsung you’d recommend reaching out to for a device profile change?
As has been pointed out by others, the mobile app can use other APIs that are not the same as the public APIs. This is likely why the capability is disabled as you observe in the AWA since it relies on the public APIs. It would require Samsung to make it so the capability was enabled since they own the integration (as @nayelyz mentions).
Additionally, the integration is OCF based which often means there are features implemented outside the API framework. This is similar to the VIPER integration for TVs.
Sorry, @Hitchin999. I don’t have the information on the exact team; I only know they have a system that escalates the tickets to teams that we can’t reach.
Turn Sabbath mode on and off automatically, plus lights and thermostats (free until November 22)
Since Sabbath mode still isn’t available in Routines, I built an app that does it for you.
Hazman (hazman.app) connects to your SmartThings account and runs everything on Shabbos and Yom Tov times for your address:
Fridges: turns Shabbos (Sabbath) mode on before candle lighting and off after Havdalah, on Samsung fridges that offer Sabbath mode to SmartThings. We’ve tested it on several Samsung models.
Lights: on/off schedules based on zmanim, such as “on at Shkiya, off 3 hours later”, with different times for Friday night and Shabbos day. It works with any light, switch or plug in SmartThings. We’ve tested Kasa, Leviton and Lutron.
Thermostats: sets heat or cool before Shabbos and sets it back afterwards. We’ve tested Honeywell Home and Sensi.
Yom Tov, two-day Yom Tov and Shabbos/Yom Tov combinations are handled automatically.
You can share your home with family members, and there are quick buttons for one-time changes.
Some fridges, including some Dacor units, list Sabbath mode but don’t actually let apps turn it on. If yours is one of them, Hazman will tell you when you test it.
It’s free until November 22. If you try it, I’d love to hear your fridge model and whether it worked
