Running a dehumidifier with Multisensor 6
Has anyone had any luck getting the Multisensor 6 to turn a dehumidifier on and off? I have used apps Humidity Alert!, SMART Dehumidifier, and I have even tried IFTTT. Non of these apps consistently work and all of them will work to turn either on or off one time and then never work again. The sensor is reporting any change in humidity every 8 minutes. I am currently using the Smartthings device handler for the Multisensor 6 but have also tried those published by erocm123 and by Robertvandervoort.
With the Humidity Alert! smartapp I am currently getting the follow log:
11:‎27‎:‎06‎ ‎AM: error java.lang.NumberFormatException: For input string: “inactive”
11:‎27‎:‎06‎ ‎AM: trace Found 10 events in the last 10 minutes
11:‎27‎:‎06‎ ‎AM: trace set point: 54
11:‎27‎:‎06‎ ‎AM: trace humidity: 57
What am I missing?
I am on the same boat have you got anywhere with this? Thanks in advance
