runIn functionality
Quick question,
In the following code, once a mode change event is triggered, runIn would kick in. But if the mode change event is triggered again, would the original runIn get reset and start again? I think it does, but just wanted to make sure thats the case
Assume XXXX is a number
def modeChangeHandler(evt) {
if (location.mode == “AwayMode”)
runIn(XXXX,“gotoyyy”)
Yes, it will be overwritten/reset as long as you don’t specify [overwrite: false].
http://docs.smartthings.com/en/latest/smartapp-developers-guide/scheduling.html?highlight=runin
