Run Routines in Response to Home Monitor Security Response?
I use SmartThings Home Monitor SECURITY. If the system is ARMED and a door or window is opened it trigger the “response” where I can sound an alarm, record video, or turn on lights.
I want to run a routine when a SECURITY intrusion response occurs.
When I create a new routine under the IF section there is “Security Mode”. But this only shows Armed (away), Armed (stay), and Disarmed.
How do I create a routine IF to detect when the Security intrusion response occurs?
Thanks in advance
You can do it indirectly in 2 ways.
  1. create a Virtual Alarm and include it in the “Sound Sirens” section.
  2. Create a Virtual Light and include it in the “Turn on Lights” section.
Then you can use the Virtual Alarm or Virtual Light in the IF section of your routines.
@Zorrloft If you have a Samsung Galaxy phone you can do this through Bixby routines.
