Hello, @mpnret
Another approach that you could try to develop your automation, is the Rules API. With it, you can define your conditional statements in a simple JSON format.
See the example below that describes the next workflow:
If
GE-SmartSwith
is ON - Wait 1 minute and turn OFF
- Wait 19 minutes and turn ON
This basic Rule will maintain the loop active, as it detects the switch state as ON.
"name": "Example Pump Automation - Turn ON for 1 minute - Turn OFF for 19 minutes",
"actions": [
"if": {
"equals": {
"left": {
"device": {
"devices": ["Your-GE-SmartSwitch-ID"],
"component": "main",
"capability": "switch",
"attribute": "switch"
"right": {
"string": "on"
"then": [
"sleep": {
"duration": {
"value": {
"integer": 1
"unit": "Minute"
"command": {
"commands": {
"command": "off",
"arguments": []
"sleep": {
"duration": {
"value": {
"integer": 19
"unit": "Minute"
"command": {
"commands": {
"command": "on",
"arguments": []
I hope this results useful to you,
Erick.
