Hello,
I have been using the rule below for some time now and it has been working great. But a couple of days ago, it simply started behaving differently, I believe due to some SmartThings update.
Here is what the rule does:
If: Between 22:00 and 7:30 AND my TV is OFF AND Motion is detected (the trigger is working perfectly).
Then: Switch off 2 lamps, Turn on 2 lamps at a determined color and brightness level, then turn these lamps off 3 minutes later. -> This is the part that is now broken.
It was working perfectly until two or three days ago. What happens now is this:
The 2 lamps switch off correctly, but then only 1 lamp turns on, waits 3 minutes, turns off, then the second lamp turns on, waits 3 minutes, turns off…
Before, the action was happening all at once, waiting the 3 minutes timers, and then turning the lamps off. Now it seem to be running in sequence, so it waits 3 minutes after the first lamp has turned on, to turn the second lamp on…
I am pretty sure this is not my mistake in the automation, as this is set like this for months and worked perfectly, until a couple of days ago something changed and I cannot make 2 lamps turn on together with an “off timer”.
Did anyone experience this same issue or knows a solution? Looks like some bug to me.
Any help is appreciated. Thanks!
