I’m using Rule Machine, and have a problem where my actions aren’t firing. I want to setup one rule where my actions are defined in one place, and I can use that rule anywhere else so that settings for a thermostat for example is only in one place… And I’m failing at getting this to work.
I have two rules with only actions defined, one for setting the heat for daytime temp and the other for setting the heat to nighttime temp. Both rules send a message when executed. To get those rule to register I initially assign them a condition. Without doing that step those two rules do not show up Select Actions->Evaluate Rules in any other rule I create.
Now I want a rule that at 5:45AM on a weekday the thermostat setting is to daytime temp. On that rule under Select Actions->Evaluate Rules I choose the rule with only actions. So at 5:45AM the first rule will execute and should execute the second rule with only actions. This does not work.
So To further test… I built out a test rig. Create a routine to turn on a momentary button. I then created a test rule to trigger on that momentary button fire. I set an action to text me when the button rule is triggered. that works… go to routines, press the test button, moments later get a text that the button was triggered. Now In that test rule I add evaluate rule and select my action only rule. First I can’t see that action only rule unless I set a condition in that rule and then it appears and I can select it.
As long as I leave a condition in my action only rule… when I press my test button, I get a text message from the button rule AND from the action only rule. I can then see the thermostat was set up or down.
When I remove the condition from my action only rule…and push the test button… I get the message from the button rule…but the action only rule is not fired.
I currently conclude a rule will not execute without a valid trigger or condition.
If I’m missing something please correct me. I can’t post screen shots as my phone has that feature locked out as I use it for work.
As for work arounds… I came up with this… Created a momentary virtual switch then trigger my action only rule off that momentary switch. Now when I want to set the thermostat, trigger that momentary switch. I’ve set that up and that works… phew
