I have two Lifx Bulbs in one fixture as my main master bedroom light. I have a number of rules set up in rule machine that turn the bulbs on, adjust the color, and set the level of the bulbs. Everything works perfectly except for the level adjustment. The brightness always remains the same as it was when last turned off. Any ideas?
That’s normal. I believe you should investigate the Capture/Restore State feature under Actions. If you need help setting the rule logic, there is a thread for that purpose:
