Rule Machine install help into IDE
(Kevin) #1
I’m getting an error when trying to create a smart app IDE using raw data, please see the error below.
startup failed: script14564194882181364357413.groovy: 101: expecting ‘}’, found ‘result’ @ line 101, column 54. " && child.label != appLabel) result << ^ 1 error
(David) #2
Hi Kevin,
Are you trying to install Rule Machine by pasting “From Code”? There are 2 SmartApps involved: Rule & Rule Machine.
If you have GitHub integration you can just go to “Settings” and connect to bravenel’s repo:
Then you will see the 2 Apps listed in the IDE:
(Kevin) #3
Ok I’ll do it that way, I was trying not to create a Github account (Lazy😆).
(Jason) #4
With rule machine frequency of updates you will want to add the repo
(Troy) #5
I am stupid when it comes to this stuff.
I now have Rule and rule machine showing in my smartapps in ide. (status says unpublished). What are my next steps? I went to marketplace-smartapps- and do not find “my apps” option or see anything related to rule machine.
(Troy) #6
Please disregard last post. I realized I did not click the publish button.
