Well… I’ve accidentally fixed it - but now I have another problem.
Whilst trying to work out what was going on I went into Rule & Rule Machine to check that I did have the latest code (which I did) - but then jut to double check I thought it may be a good idea to hit publish again… accidentally pushed it for Rule and not Rule Machine !!
However - now I see the extra options under actions! But now I just need to know - what will happen now that I have published Rule?
Well no harm actually, now you just to be sure that you publish both rule and rule machine in the future. Once rule is published, it cannot be un done without deleting the whole thing and starting over. That’s an ST feature…
Don’t feel bad, I did this too!
We’ve extended Rule Machine to support multiple custom commands per rule.
This allows a rule action to process multiple separate commands within the same action.
Prior to this update Rule could only process one custom command per action.
If you currently have any custom commands configured, the existing commands will need to be refreshed in order to work after the update.
To refresh an existing command, tap any “Select Actions sections” containing your custom commands.
Actions that contain a custom command are preceded with the word “Command:”
Scroll to the bottom and tap “Run custom device command(s)”.
Your existing command should appear in command slot number 1
Tap done, the command should now appear in “Run custom device command(s)”
Tape done again, and done to finish.
Your existing custom command is now refreshed and should function as expected.
To add an additional command to an action:
Within the action, select “Run custom device command(s)”, then select your devices and command in the next available slot. This works the same way as the conditions section in Rule.
To remove a command from an action:
Commands must be removed in reverse order, IE 3, 2 then 1.
To remove a command, deselect any devices from the Custom Devices list.
If you have two custom commands configured and you want to remove the first one, copy #2 into #1’s slot, then delete 2.
This feature requires Rule Machine 1.6.4 and Rule 1.6.6 or later Rule Machine
Probably my lack of expertise, but I want to create an expert rule to tell my Sonos to play “Welcome Home Justin”. I select PlayTextandRestore then ‘String’ then I enter Welcome Home Justin and when I go to test, I receive this error.
sure can, then you would use one of the playTrack methods.
They only accept external URL’s, so the URL needs to be available on the internet someplace.
This is one of the super simple things to add, I couldn’t resist. I did see your post, and messed around getting Echo to speak, although the voice is disappointing. Then heck, why not…
bamarayne
56
This is great… I just deleted another app! I like to keep it simple and efficient.
But man is my list of rules getting huge!
Edit:
I wish ST had a drag and drop format. Then we could set up our rules in categories…
-Doors/Windows
-Kitchen lights
-Living room lights
Or just lights
-alerts
-custom
That would be great… And so much more user friendly.Lol
bamarayne
57
You would think that with today’s technology, they could get a decent tts voice…
