I recently built a tool called Rule Builder and wanted to share it with the community.
Rule Builder is a no-code automation builder for SmartThings Rules API.
Rule Builder is a free tool that lets you create advanced SmartThings Rules API automations without writing JSON manually or learning Rules API syntax.
Build automations through a step-by-step guided interface. The generated Rule can then be imported directly through the SmartThings Advanced Web App.
No installation, SmartApp, registration, or subscription is required.
Rule Builder focuses on automation patterns that are commonly implemented through Rules API, especially for IoT buttons, knobs, remotes, and dimmers. Many of these automation patterns are difficult or impossible to create using the standard SmartThings Routine editor.
IoT Button Routine Presets
Light Brightness Control
Press repeatedly to increase or decrease brightness step-by-step.
Light Color Temperature Control
Press repeatedly to make lighting warmer or cooler.
Light Color Control
Cycle through lighting colors using a button.
Fan Speed Control
Use the button to adjust the fan speed in steps.
Audio Volume Control
Adjust the speaker or TV volume step by step, just like a real remote control.
Curtain / Blind Control (Window shade)
Adjust opening percentage incrementally.
Air Conditioner Temperature Control
You can raise or lower the target air conditioner temperature with buttons just like a real remote control.
Air Conditioner Fan Speed Control
Adjust the air conditioner fan speed step by step using a button.
Air Purifier Fan Speed Control
Adjust the air purifier fan speed step by step using a button.
IoT Knob Routine Presets
Use a knob like a physical dimmer.
Rotate to make lighting warmer or cooler.
Light Color Control
Rotate to cycle through lighting colors.
Fan Speed Control
Adjust fan speed naturally with knob rotation.
Use the knob like a physical volume dial.
Precisely control curtain opening percentage.
Adjust the AC target temperature by rotating the knob.
Adjust the air conditioner fan speed naturally by rotating a knob.
Adjust the air purifier fan speed naturally by rotating a knob.
Available in Korean and English.
Try it here:
