Routine Actions Ran, but some of them Didn't Work Correctly
I have a manually run routine that turns off lights, closes garage doors, etc. Lately when I run it, I get the above error that it ran, but not everything worked correctly. The error message lists all the devices in the routine, rather than the one that didn’t work. As far as I can tell, they all work, though. Is there some way I can run the routine and tell which devices failed? Thanks.
Hi, @rcbjr2
Have you reported this to Customer Support? I don’t have details about the error message displayed to confirm it should only show the problematic devices, but all are detected as such for some reason in your case.
No, but I guess I should. I thought maybe someone else has had this issue and knew how to trace the error. Thanks.
By the way, I figured out it’s my Kwikset locks that are causing the error. I created two routines, one with just locks and one with all the other devices in the original routine, and only the locks one give errors. Locks all lock, thought. They aren’t installed as Matter locks, but rather thru the Kwikset integration.
