ROUNDUP: Data Logging and Charting Solutions
I have both Vera and ST
So I have seen people other solutions which have no specific integrations with ST, same here. If somebody can give me an idea how to push data from ST to hundredgraphs I would love it
SmartApp to log data to https://www.hundredgraphs.com and get graphs back from data, you can get it here
HundredGraphs accepts any data (the dry/wet, active/inactive are converted to 1/0) and makes graphs out of it. The account is free
Cool, but…
How / why is this free? Data storage and bandwidth can become tremendously high operational expenses…
Storage is cheap shit nowadays. Bandwidth is a bit more expensive when it is every minute, but not that much (it is less than KB). The service is freemium. So far we have only free level, but it is going to be a premium as well.
We are never going to charge for pushing data from your ST to HundredGraphs and to create nice graphs.
But our main aim is smart home owners who would want to get energy optimization pushed back to smart hub, for that you need a lot of users/data to run through AI pattern recognition. And that obviously would be premium. But hey! You can save about %25 of the monthly bill (industry research).
@ipstas
Have you got this working?
I am not seeing any feeds from ST but if i try the test in API docs it seems to be working on their end.
I see this in my logs.
e4e5633d-8d60-46eb-8990-f4b30b71cb93 6:27:30 PM: warn Unexpected response from HundredGraph Logger: 401, Failed with status code 401
@scpickle Looks like we got a bug, the default url was pointed to the dev server instead of prod. There is a new version in git or you can change it manually, just replace http://dev.hundredgraphs.com/hook/ with https://www.hundredgraphs.com/hook/
Sorry for that and thanks for trying
Tried Hundredgraphs, but keep getting this error:
error java.lang.IllegalArgumentException: Failed to complete. Message was: Read timeout to HundredGraphs, visualize and smarten up your IoT data of 20000 ms @line 691 (processLogEventsResponse)
warn Unexpected response from HundredGraph Logger: null, Failed to complete. Message was: Read timeout to HundredGraphs, visualize and smarten up your IoT data of 20000 ms
Here’s another method to add to the roundup - using IFTTT. With SmartThings and Google Sheets connected there you can create an applet that adds all events from the device into a google spreadsheet. Has been working great for me for months now.
@oliver989 I hope everything is working now?
Yes it is working now.
But there seems to be a bug with the graphs. “The first selected feed sets a max range for the graph”, it seems that the range is actually set according to the feed that is first alphabetically. This is really annoying, because in my case that sensor is mostly off.
It looks like a bug, but I can not replicate it. Would you mind to share a graph?
Are there any programs here that would be able to monitor the energy usage data from the Tp-Link TP-110 and then relay it to Smartthings to trigger a switch. Energy reading of 0 would shut off switch and when any energy is detected it would turn on switch.
I did set up a node but realized I apparently would have to buy Sense and create a sense account in order to have the data from the Tp-110 to relay over.
Thanks Everyone
Does your IFTTT applet have Google Sheets recording all Smartthings activity? I can’t seem to figure this out.
2022 Update
many of the integrations listed in this thread are either no longer available or will not work once the transition to the new architecture is complete.
There is a new one that was just introduced from what looks like a start up company that is designed to work with the new architecture. I don’t have any personal experience with it, but I wanted to list it here for those who are looking for something current.
Eventually it will have a free tier with limited reports and then paid tiers with more features but right now it’s free to try.
If you give it a try and want to review it, please add that to the project thread rather than this one. Have fun! :sunglasses:
ConstantGraph Data Logging and Charting
